Thread: Scarlet/ Epic S35 is only 2:1 @5k 30mmx15mm
Results 1 to 4 of 4
  1. #1 Scarlet/ Epic S35 is only 2:1 @5k 30mmx15mm
    what's with the S35 sensor area of 30mm x 15mm?
    That's 2:1!!!!
    So epic adds extra width, but not so much extra Height.
    It won't be a 5k camera if you're shooting 16:9.
    It'll be about 4.4k.
    Jim- put a PL mount on the Monstro cameras!!
    Pixel count would end up being the same as your S35 for 16:9, despite the 6 micron pixel size, as you could shoot 30mmx17mm.
    Mark Pugh LA,NYC, and AUS.
    www.markpughfilms.com
    Several EPICs...
    Senior Member Brandon Fraley's Avatar
    Bay Area, Ca.
    i think that was a typo, but maybe not.
    And, again, I'm sure you can use PL mount lenses on Monstro camera, you just can't shoot Full Frame 35mm, which is a limitation on the lenses, not the camera.
    A double typo?
    Also written there is "max resolution" of 5120x2700, which maybe includes look-around, but even that only gives a 1.89:1 ratio
    Several EPICs...
    Bay Area, Ca.
    single typo, I think the 1.89:1 is probably right.
