Thread: Epic Accessories
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Feb 2008
    EHT, New Jersey, USSA
    Quote Originally Posted by Obendega View Post
    I saw one render with a RED drive attached by something that looked like Element Technica's v-dock drive mount system.
    http://www.elementtechnica.com/vdock/
    Okay, yeah... I just saw it... It's in the "more renders" thread right?
    I do have a Red One, and it all makes sense once you see everything in person. The top mounts and the CF module don't work for Epic because of their physical form factor - they're made for Red One's body. Red One is almost completely modular - everything else attaches to the rods or the bottom. About the bottom, the ET or Red One baseplate will fit on the Epic with an "inexpensive" adapter. Jim has made all this clear. That means that there must be places to plug in Red One's battery, Red Drive, LCD, EVF, etc. And all the mounts for battery and Red drive attach to the rods, so they would just attach to rods on Epic. You will be able to use your rods too, as they are just industry standard 19mm rods (I don't know if Epic will have 15mm options, but I'm sure they will).
    I have no idea if the Birger mount would work on Epic, so that is another factor for people planning to use it on Red and then upgrade to Epic.
    So as I understand it, the additional things one would need to go from a Red One package to an Epic package would be the "brain", top mount (for mounting rods to the top), bottom mount adapter (for using the ET or Red One baseplate), and I/O module (assuming you want to record audio to Epic and to monitor video on HD-SDI and so forth). Then you could add Epic/Scarlet specific things as budget allows, like the battery module and Epic LCD, EVF, etc.
    Matthew Verkler
    Nov 2008
    Seattle Area, Washington
    Quote Originally Posted by Andrew McCarrick View Post
    Isn't this a RED Drive mounted on top?
    I know they have said the Batts are going to be usable at this point but nothing else is confirmed.
    Peace,
    Darren Orange
    CEO / Producer
    Chicago, IL
    Reactor 88 Studios
    W: www.r88s.com / www.bnwmovie.com / www.4kchallenge.com
    E: reactor88@r88s.com
    Twitter
    www.twitter.com/Darren_Orange
    www.twitter.com/R88S
    Feb 2008
    Quote Originally Posted by Austin Glass View Post
    Yep... that's the render I was refering to.
    Quote Originally Posted by Greg Merkes View Post
    OK, so when you look at the Epic picture and how all the components are placed on the back - it seems that they have a different battery system as well as drives. So I have to question weather or not the "new" epic batts and drives are going to be better than the "Red One" batts and drives. It seems to be a big secret. . .
    From what I understand there will be new accessories, but the old ones (except what has been mentioned already) will still work.
    Dylan Macleod, CSC
    Cinematographer
    LA/NY/TO
    www.dylanmacleod.com
    Senior Member J. Bernard Vallon's Avatar
    Maryland, USA
    The Drive will most likely work, if only at lower datarates. There will definitely be a faster RedDrive released to keep up with the faster redcodes. Id imagine those would be backwards compatible as well.
    John Bernard Vallon
    JBV Media
    443-834-9023
    john (a) jbvmedia.com
    www.jbvmedia.com
