26.3 OpenEXR Data Compression
OpenEXR offers three different data compression methods, each of which has differing trade-offs in speed versus compression ratio. All three compression schemes, as listed in Table 26-2, are lossless; compressing and uncompressing does not alter the pixel data.
Table 26-2. OpenEXR Supported Compression Options
Name
Description
PIZ
A wavelet transform is applied to the pixel data, and the result is Huffman-encoded. This scheme tends to provide the best compression ratio for photographic images. Files are compressed and decompressed at about the same speed. For photographic images with film grain, the files are reduced to between 35 and 55 percent of their uncompressed size.
ZIP
Differences between horizontally adjacent pixels are compressed using the open-source zlib library. ZIP decompression is faster than PIZ decompression, but ZIP compression is significantly slower. Compressed photographic images are often 45 to 55 percent of their uncompressed size.
RLE
Run-length encoding of differences between horizontally adjacent pixels. This method is fast, and it works well for images with large flat areas. However, for photographic images, the compressed file size is usually 60 to 75 percent of the uncompressed size.
Optionally, the pixels can be stored in uncompressed form. If stored on a fast file system, uncompressed files can be written and read significantly faster than compressed files.
