Thread: How to Fit a Full Red One Kit in a Pelican 1650
Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1 How to Fit a Full Red One Kit in a Pelican 1650
    In case any of you are interested, here's one variation that works...the first photo has hover-over notes...
    http://www.flickr.com/photos/stephen...7611636990175/
    Senior Member mikeburton's Avatar
    Sep 2007
    Sacramento CA
    Nice! I have the 1650 as well. Do you have a connection for the custom foam? I would like to get something similar.
    Senior Member michael zaletel's Avatar
    Apr 2008
    Phoenix, AZ
    1620 is a great case as well. Not as Long (by 6 inches), About same width but gives you an extra 2 1/2 inches of depth for safety top and bottom.
    1650 case dimensions:
    Outside Dimensions 32-1/2" L x 20-1/2" W x 11-15/16" D
    Inside Dimensions 29" L x 17-7/8" W x 10-1/2" D
    1620 case dimensions:
    Outside Dimensions 24-13/16" L X 19 3/8" W x 13-7/8" D
    Inside Dimensions 22-1/16" L x 17" W x 12-9/16" D
    -shooter
    nice work. I had a similar setup but after a month of rigorous use that pluck foam got thrashed up. If you never intend to rent it out, it likely won't last unless you baby it. A laser cut version would be sweet.
    I have a Pelican 1630 that holds a large amount of kit - camera, EVF, LCD, cables, drives and Pelican CF holders, AC adapter, etc... It's great, but can be a bit unwieldy at times. I find that if I'm fully aware of the kit I'll need and I don't have much help, I'll load the camera and kit I need into my big Tamrac backpack.
    As for the pick and pluck or cubed foam, it's great if you're setting up a case and you don't know what you will be doing exactly for layout. Use the foam to customize and tweak your layout. Once I'm happy with it, I take the cubed foam stuff and use it as the template for laser cutting. The cubed foam just does not hold up over time and it makes crumbs as it falls apart.
    - Jeff Kilgroe
    Member Darrell Essex's Avatar
    Northern California
    Sbove, can you post some larger pictures here?
    Senior Member Shawn Booth's Avatar
    Honolulu. HI
    Why store the EVF vertically?
    Senior Member Alexis Hanawalt's Avatar
    Mar 2007
    Los Angeles, CA
    Gotta pimp my own case foam design again here... http://reduser.net/forum/showthread.php?t=21197
    Alexis Hanawalt
    Bolster Camera, Inc.
    www.bolstercamera.com
    Quote Originally Posted by Cinewalt View Post
    Wow! That rocks. Way beyond the "finger-cut" foam cubes!
    Quote Originally Posted by Shawn Booth View Post
    Vertical "depends" on which way the case is being carried...This choice was based on fitting in everything else...its quite a multi-variable equation...
