Thread: Kind attn: Michael - Audio non-sync in 24p PAL Project?
Results 1 to 5 of 5
  1. #1 Kind attn: Michael - Audio non-sync in 24p PAL Project?
    Senior Member gbalaji's Avatar
    Chennai, Tamil Nadu, India
    Michael
    I try export ALE from Red Rushes.
    Created 24p PAL project
    In format changed to 1080p24
    Imported the ALE
    Selected all clips and modified and added audio track 1
    Changed the format settings to 24p PAL
    Batch imported the files
    When I try to play the file the audio is non-sync and early than video?
    Please suggest the reason for non-sync and I have already imported 2500 clips worth of material running for 10 hours.
    G.Balaji
    Digital Cinema Designer
    File based workflow & Post Supervisor for Film & Digital Cinema Cameras Red EPIC, Arri Alexa,Sony F23 / F35, SI2K, Phantom Flex & Canon 5D
    www.indieshd.com
    gbalaji@gmail.com
    Ph: 91-9840224733
    Twitter - http://twitter.com/gopalbalaji
    Film Credits: Margazhi Raagam, Thiru Thiru Thuru Thuru, Pookisham, Tamil Padam, Ethirmarai, Whirlpool S3D commercial, 180, Vazhakku EN 18/9, Thangameengal,Vallinam, Spanish Masala (Mal), David (Hindi), Thupakki, Thaandavam.
    Aug 2007
    Boston
    What 24p PAL project did you make, Method 1 or 2? I would also import all the audio into the 1080p project to start -
    Michael
    I'm using method 1. Is the method 3 you mentioned in earlier post ready yet?
    G.Balaji
    www.indieshd.com
    gbalaji@gmail.com
    Ph: 91-9840224733
    Aug 2007
    Boston
    Method 3 is a concept only. Not any engineering roadmap at this time. With HD post becoming easier and cheaper, the priority to enhance SD workflows for high rez production goes down. It is something we are tracking, but not it is not the top of the list.
    Import your audio in the 1080p/24 project first.
    Michael
    Thanks Michael.
    I now move to 1080p24 project in DnXHD 36 codec. Will follow for my next project for using SD under method 2.
    G.Balaji
    www.indieshd.com
    gbalaji@gmail.com
    Ph: 91-9840224733
