Thread: REDrushes vs Log and Transfer
Results 1 to 5 of 5
  1. #1 REDrushes vs Log and Transfer
    Senior Member Sam Roberts's Avatar
    Apr 2008
    Toronto
    What are the differences, if any, between FCP Log and Transfer and Redrushes when it comes to picture quality (both set to ProRes 422 HQ) and speed of transcode?
    FCP can't saturate all CPU cores like RedRushes can.... And the FCP transcode still has the gamma shift like the proxies. RedRushes gives more output options and the ability to burn timecode as well as set debayer quality.
    I'd use RedRushes over FCP L&T all the time.
    Braunschweig, Germany
    Or have a look at Clipfinder…
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    Senior Member Kaku Ito's Avatar
    Feb 2008
    Chiyoda-ku, tokyo
    Since ClipFinder can read edited XML from FCP to choose only the necessary R3D files AND by double clicking to open it with REDAlert! to do some one light color correction and save it as RSX that can be applied in ClipFinder's quick render future, I've been using ClipFinder more than REDrush nowadays. I'm not really a big fan of L&T.
    Kaku Ito
    rawesome! Equipments
    RED Epic-M, RED Epic-x, RED ONE MX x2, RED ONE Mysterium, Allstar A-mount, Epic Canon Ti Mount, 1.8' SSD modules, RED PRO Prime Set (18 through 100mm), various Nikon and Zeiss Lenses, 17-55mm RED Pro Zoom, 18-85mm RED Pro Zoom, x2 RED ROCKET, Mobile Rocket, DaVinci Resolve, Cubix, GTX-285, Quadro 4000, few Mac Pros, few MacBook Pros, Sony BVM-D24, Panasonic 65 inch Series 12 plasma, Calman with Klein probe.
    Rawesome! One Stop RAW Visual Production Service
    According to the RED/FCP White paper that you get from RED when you download the L/T plugin, I thought that the original camera settings/look were preserved during import:
    The Color, Color Temp, and View RED camera settings in use while shooting are stored as metadata within each recorded R3D file. When you transcode R3D media to ProRes 422, this metadata is used to preprocess the color and contrast of the transcoded media as long as the “RED FCP Log and Transfer plugin” submenu of the action menu is set to Native, which is the default setting. The result is that each transcoded clip visually matches the image that was monitored during the shoot. This preprocessing is “baked” into each ingested clip. If you want to later reapply a different type of image preprocessing to a clip, you need to reingest it.
    Are you stating that luma & chroma are altered during the L/T process even when you choose NATIVE as the import method?
    Thanks.
    Scott
    Scott A. Ettin
    Manager
    Digital Media Services
    Postworks NY
    100 6th Avenue, 10th Floor
    New York, NY 10013
