Thread: A good wide angle for the Zeiss ZF
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
  1. #31
    Senior Member Steve Sherrick's Avatar
    Boston
    Quote Originally Posted by Richard Darge View Post
    I have been using the 17-35 f/2.8 for quite sometime and although the focus pulling is a little bit of a pain, once you get used to it, you're alright.
    I use the 17-35 75% of the time because its so sharp, colors are great and its compact and covers me pretty well. I need to check out that 17-55 however, seems like a great lens for the money. Douglas, have you done any comparisons with the 17-35 VS. the 17-55?
    I just picked up that Tokina 11-16 and can already tell that it will become the new workhorse in my kit. Simply amazing clarity and 11mm is so much fun to have.
    Best,
    We're running similar kits. The Tokina is great. I'll be using it for a lot of stuff. If the 17-55 is sharper than the 17-35, it's not by much but you do gain the extended range which is why Doug loves it and why I contemplated selling the 17-35.
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    I don't have any lens comparisons, just some observations from the last shoot, on my 1440 x 900 monitor (which of course isn't all that HIGH def, really)
    I want to load build 17 so I can do the 1:1 pixel zoom thing and see what's what, maybe get a Putora chart and see how many lines, etc. To tell you the truth, I really go by the feel of the lens once I put it on the camera, and the 11-16 just looks like a gas. Great for POV stuff - I can already see shots inspired by RAISING ARIZONA, flying through the supermarket looking for disposable diapers . . .
    Jan 2008
    For what it is worth, before I decided on either the 17-35mm or the 17-55mm Nikons, I had the opportunity to talk face to face to a Nikon USA lens technician at the Torrence facility, and I asked him which lens he thought was sharper and had better contrast. Without a pause, he said it was the 17-35mm. I am sure it varies some from lens to lens though. I chose the 17-35mm, but do miss the extra push the 17-55 affords.
    Senior Member Sanjin Jukic's Avatar
    Vienna, Austria
    "AF-S Zoom-NIKKOR 17-35mm f/2.8D IF-ED FF35 lens
    High-performance, ultra wide-angle zoom lens, perfect for candid photography
    and news photojournalism in challenging lighting conditions."
    LINK>>
    "AF-S DX Zoom-NIKKOR 17-55mm (25.5-82.5mm FF35) f/2.8G IF-ED (APS-C 1.5x-crop from FF35)
    This high-performance, wide-angle zoom is designed exclusively for use with Nikon’s DX-format,
    is fast and versatile for travel and portrait work."
    LINK>>
    "Tokina 11-16mm f/2.8 AT-X 116 PRO DX (APS-C Nikon 1.5x & Canon 1.6x crop from FF35).
    The new Tokina 11-16mm (16.5-24mm FF35) f/2.8 AT-X 116 PRO DX is an ultra-wide angle lens with a fast f/2.8 aperture for better
    photography in low-light situations. Many photojournalists consider having an f/2.8 aperture a must
    for any lens in their camera bag."
    LINK>>
    So AF-S DX Zoom-NIKKOR 17-55mm (25.5-82.5mm FF35) f/2.8G IF-ED is out.
    And the winner is AF-S Zoom-NIKKOR 17-35mm f/2.8D IF-ED FF35 auto and manual focus/iris lens.
    "There is no point in having sharp images when you've fuzzy ideas."
    Jean-Luc Godard.
    Dynamic range is, after all, the measurement between well saturation (photosite blowout) and noise floor.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    From your link, Sanjin:
    17-55
    DX design enables a combination of wider angle-of-view with optical characteristics that are optimized for Nikon digital SLR camera sensors.
    Nikon DX design produces a smaller image circle (the size of the image that is projected by the lens on to the sensor) enabling smaller lens diameter, lighter weight and optimal image quality from center-to edge-to-corner on the imag
    e.
    Well someone should shoot some charts to see which one is the winner, I think.
    Senior Member Rick Darge's Avatar
    If someone wants to loan me their 17-55, I will gladly do a test at my home. I have a little chart I can throw up, and I can do some quick real world dirty tests. I'll compare the 17-55's 50mm focal length up against the Zeiss 50 and I'll throw on the Tokina too.
    Just need a 17-55 for the night.
    ANGENIEUX LENSES • CANON k35 SUPERSPEEDS PL
    O'CONNOR • ARRI • DEDOLIGHT • KINOFLO • LTO5
    www.theredshooter.com
    rgdfilms@gmail.com 310-435-3134
    WWW.ZENDOGMOVIE.COM
    Jan 2007
    Keep in mind the 17-35mm isn't as wide and costs about twice as much as the Tokina... I agree that it might be a better investment for a current ZF set but they are different beasts. Both would be perfect with a 28mm 35mm 50mm 85mm ZF set. And while neither are so long that you would freak over the focus ring they still can't compare to the ZF rings... ugh...
    Less money less headaches.
    Writer - Director
    Crowing Lakes.com
    Vienna, Austria
    Ultimate 15mm FF35 still lens is
    Leica Super-Elmarit 15mm f/2.8 ASPH
    "Distortion is in general very well corrected and even per-
    sons at the edges of the image retain their normal body
    contours. (Ever looked at the elongated faces and bodies of
    persons when using a 12 mm or some other 15mm len-
    ses?). Architectural straight lines are straight lines with a
    just visible distortion in the outer zones of the image."
    but costs you "only" US $ 8,995.00 (B&HFVNYC) :) .
    Jean-Luc Godard.
    Thom Hogan
    500px >>>
    Twitter >>>
    Facebook >>>
    Vimeo >>>
    Senior Member Steve Sanacore's Avatar
    Oct 2007
    Miami Florida
    Quote Originally Posted by Sanjin Jukic View Post
    I've been on waiting lists for a used version for over a year now ... very hard to find used lens.. but the best 15mm ever, as most Leica lenses are.
    Steve Sanacore
    Photographer/Director/DP
    www.stevesanacore.com
    How bad is the distortion on the Tokina 11-16mm?
