Click here to go to the first RED TEAM post in this thread.   Thread: problem with cf card 16GB
Results 1 to 7 of 7
  1. #1 problem with cf card 16GB
    Banned
    Oct 2007
    I put the 16GB cf card into the camera, the camera showed ERROR, something like, not recognized magazine...only 2k.... I tried to format the card, the camera start format and continue format on and on... after 5 minutes that nothing happened, it continue to show format, I reboot the camera.
    I put the card again and now the camera doesn't recognize the card, there is no response. With other cards, everything is ok. but with this 16GB red card, no response...
    I have build17 and upgrade cf card module.
    I use this card in the past, and it was ok.
    any idea what can I do?
    I tried to put the card into pc computer, and also nothing...
    Glik.
  2.   Click here to go to the next RED TEAM post in this thread.
  #2
    Sounds like a faulty card that will need to be sent in to us for eval. I would contact tech support via RED.com.
    BC
    same problem with my 8gb
    red told me to reinstal the cf module. work for me
    no more error
    Mar 2007
    Quote Originally Posted by ale@alexandreermel.com.br View Post
    no more error
    Alex, what do you meant by reinstalling the CF Module? The module is a hardware. Are you replacing it with a new one or just unplug and plug? Lim
    Junior Member
    Oct 2008
    yes apparently I got the same error I would like to know how to reinstall that module.
    thanks
    Chris
    Hey guys,
    Any news on this? .. we are having a problem reading our RED 8gb cards in the camera as well. Would be great if we could just re-seat the CF module or something rather than sending it halfway round the world to be repaired :/
    Seth Larney
    Director
    www.chaoticpictures.com
  7.   This is the last RED TEAM post in this thread.   #7
    If you are handy with a 2.5mm hex key, remove the four screws from your CF MODULE (panel that says RED) and remove their four washers. Remove the panel. CF reader/writer will be connected to camera by two wire bundles. Confirm the two wire bundle connectors are properly connected to reader/writer. When done, reverse process to put panel back on.
    Note, if you are changing your reader/writer (ie, you bent a pin or something), follow same steps - but after removing panel, remove the two wire bundles (be careful to not pull directly on the wires, but rather on the connector). Remove the three screws on reader/writer, swap reader/writer. Reverse instructions to complete.
    Hope that helps,
    BC
