hi
I have some questions about the workflow.
1.) the red drive got 320GB. It depends on the format I shoot, or does the red drive work with every definiton, also 4K???whats exactly the difference between this cheaper resolution and the expensiver RedRam....and for what are the other modules???
2.) if I shoot 4k. I have RAW Data not RGB 444. thats also the reason why the datarate is lower. but is the definiton of the red than not lower than the 4k (DI) of an 35mm Film. Because in the film I have different layers depends on the wavelenght of the light, an so 3times the higher definition
3.) which is the standard amount for lenses??We have P&L Mounts...do I need an adapter???
thanks a lot for your help...and I am sorry for my bad english
greetings
D.
