Thread: Wrappers not showing up out of REDrushes
Results 1 to 5 of 5
  1. #1 Wrappers not showing up out of REDrushes
    Junior Member
    Jul 2008
    I'm trying to import some clips from a reshoot creating the QT wrappers and ALE out of rushes. We did this before, but my assistant, who is no longer available took care of the importing. I am following the AVID guide, but when I click "Make QT wrappers", nothing is showing up in the output folder. I know we had this same issue before, and that it was easily fixable, but I can't get a hold of my assistant, nor do I remember what he did to fix this problem. Any ideas?
    Junior Member
    Jul 2008
    I should also mention that this is using version 3.5 of rushes. I'm hesitant to update and have the files from two versions in the same project. Is this a valid concern or should I just update to version 3.6?
    Aug 2007
    Boston
    In earlier versions of REDrushes the folder name as the target cannot have spaces in it.
    So "Dailies Folder" needs to be names "Dailies_Folder" or "DailiesFolder"
    Michael
    Junior Member
    Jul 2008
    Thanks Michael. I knew it was something stupid like that!
    I ended up just updating to 3.6. Is it going to be a problem when conforming that most clips have the +1 added to the start tc and these new clips have no modification, or will it make no difference down the line?
    Aug 2007
    Boston
    The +1 is added to the tail of the shot to not force the Media Composer to squeeze 10 frames of media into a 9 frame slot.. (or whatever the duration of the media might be). The issue with not having the +1 is that Avid makes "the shoe fit" by dropping a frame in the middle of the clip meaning that metadata will be off by 1 frame from the middle of each clip to the end. You want to have the +1 as part of the ALE. This was a great addition to this version as well as the ability to render to QT wrapped DNxHD directly which is fast than transcoding during import since it used more than 2 processors if available.
    Michael
