Thread: Sharpening
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
  1. #1 Sharpening
    Senior Member Chris Bell's Avatar
    Sep 2007
    I'd be curious to hear about favored methods of sharpening. Where do you set the OLPF compensation? Low, Medium, or High detail? No sharpening in RedCine...do you sharpen in post with the tool in Final Cut?
    Advice welcome....
    Chris
    Senior Member michael zaletel's Avatar
    Apr 2008
    Phoenix, AZ
    Hi Chris:
    Sharpening is tricky enough for still images. There are so many variables to consider. My preference is to leave sharpening until the very last step after grading even. Reason being that when you make any changes to color balance, gamma, contrast, tint to match shots, you modify the edges of images. If you do the sharpening prior to grading, you run the risk of emphasizing or downplaying your sharpening in certain parts of the image. Also, just like with still images for print, you want to apply different sharpening settings (or unsharp mask or smart sharpen settings) for different output resolutions. For example, you would use different settings for the HD version than you would for SD version or web resolution versions. Also, compression for web can do crazy things to pre-applied sharpening. Therefore, my advice is to avoid sharpening, unsharp masking or smart sharpening until you've finished the master, then apply sharpening based upon how you are planning to output or display the footage and remember to use different settings for different output sizes, resolutions, compressions.
    EDIT: Also, many times it is best to sharpen locally within a feather-edged mask or use same method to apply varying levels of sharpening.
    -shooter
    Sep 2007
    What software are you using to perform sharpening?
    Hi Guys,
    This is a topic that I'd quite like to hear more about and therefore post this reply as a way of getting it back onto the top of most recent posts.
    Where are your favoured methods of sharpening aplied and what do you find gives best results. (I find my workflow is based on whatever the client is most used to and a lot of the time I have little control over paying jobs.)
    So come on guys get with the replies!
    Mike C
    Senior Member Shawn Booth's Avatar
    Honolulu. HI
    Quote Originally Posted by spotshooter View Post
    I follow the "sharpening" whenever it is brought up. I believe most employ the After Effects>Unsharp method. At the end of all work. Final step before output.
    #994 - Cassavetes
    Sep 2007
    Shawn,
    What settings do you use in Red Cine? Detail setting? OLPF?
    Quote Originally Posted by Shawn Booth View Post
    What settings have you found to be good in AE's unsharp mask? Thanks
  8. #8 Sharpen at final size
    Senior Member Dan Hudgins's Avatar
    Feb 2007
    San Francisco, CA USA
    I would add that you should only sharpen up at the final output size, if you sharpen a 4K image then down res to DVD size you can get worse aliasing.
    In fact before you down size you may need to blur the image to avoid aliasing in the smaller version.
    If you sharpen early on too much you can get the video look and worse noise in the images.
    Sharpen/unsharp mask can help with using fast lenses like f/1.2 since they have a halo around the image details.
    Dan Hudgins is developing "Freeish" 6K+ NLE/CC/DI/MIX File based Editing for uncompressed DI, multitrack sound mixing, integrated color correction, DIY Movie film scanning, and DIY Movie filmrecorder software for Digital Cinema. RED (tm) footage can be edited 6K, 5K, 4.5K, 4K, 3K, 2K, or 1080p etc. see http://www.DANCAD3D.com/S0620200.HTM (sm) for workflow steps.
    When using Red Alert to output 2k ProRes HQ for pre color grading, what settings should be used for Chroma Denoise/De-Moire and PLPF Compensation if I want to maintain a pristine workflow and not introduce artifacts?
    The default setting are maximum and high respectively. Debayer Detail is also default at high.
    Brad
    Brad Stoddard
    Stoddard Communications of New Mexico
    Honolulu. HI
    Shawn,
    RC -
    Sharpen - leave on default 50.00
    detail: Medium
    NR: Enabled
    I'm the first to admit though, I'm still learning.
    I also believe though, every shot requires its own settings. "This shot gets HIGH Detail" while "That one gets 0 Sharpen"....
    Honestly, I don't know...
    #994 - Cassavetes
