Thread: A wishlist for Epic.
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1 A wishlist for Epic.
    Senior Member I Bloom's Avatar
    Jan 2007
    Manhattan
    Hopefully I'm not coming in way late on this. Maybe some of these could be considered firmware ideas for Red One.
    Things I'd pay good money to have on set:
    1. Seperate display setups for operator, focus puller and client output:
    So that if the operator decides to look at false color or RAW for example, the client still sees the look.
    2. 1:1 Zoom while rolling, that can display only on the LCD and not the EVF:
    Essentially part of #1. But so important, it's worth it's own number. Great if the focus puller could quietly move the sub-image around the screen during the shot.
    3. Support for two LCD's rather than specific EVF and LCD ports:
    It would be great then for the focus puller to have his own LCD when the operator decides to use an LCD. I'm watching every seasoned film operator I've worked with start operating off the LCD, on a lot of setups it just makes more sense.
    4. Support for LDS:
    I would be great if Epic could support LDS lenses. I love Cookes but I'm more likely to be shooting on Zeiss for visual effects heavy work when lense data is most important.
    Best case scenario: Both LDS and /i support in one PL mount.
    Also great: a seperate LDS mount option that can be swapped in.
    Another option: a port on the mount that gives access to the pins to third party devices such as a conversion box or recorder.
    5. Waveform and vectorscope overlays:
    I would suggest that the current waveform on RedOne is simply too short to be useful, my hope is for a larger waveform that can be momentarily displayed over the whole image. A vectorscope as well would be a wonderful addition. Often the person who needs to see this the most is the gaffer, so I'd suggest a small corner overlay that can be transmitted just to the HD-SDI output. If that graph could display the clip point for both the RAW and LUT at the same time that would also be amazing.
    6. High Saturation View:
    If you watch a video engineer at work you will often see them momentarily oversaturate the image. This allows one to see exactly what hues are present in a given part of the image. Especially useful when green or magenta light is leaking onto skin tones from some misbehaving instrument. Red One can already do this, but it would be great as a hot key/false color mode and more extreme saturation than is available currently.
    7. Most complicated:
    I find it problematic that my look settings affect the false color exposure display. I'd like to simulaneously switch to RAW whenever I view false color.
    I have a few other ideas...
    Much respect,
    IBloom
    Good suggestions. I like 'em all. LDS has been asked for by several people here over the past year or so. I guess we can keep asking. :)
    1:1 while rolling would be great. I don't know why you would not want it on the EVF. There are times I'm in intense light conditions outside where the EVF is my only viable means of monitoring.
    Kinda related to #6 and maybe #7. I'd like to be able to load a couple different looks onto the camera and be able to quickly toggle them or assign them to certain buttons. As for overlays, those would be handy. I'd also like the ability to overlay an image or possibly a video clip with an alpha channel or user selectable transparency value.
    I think most of these have all been suggested as potential upgrade features for the RED One. I hope some make it into EPIC, all would be great. ;)
    - Jeff Kilgroe
    REDuser Sponsor Brook Willard's Avatar
    Burbank, CA
    Agreed on all counts. :)
    Jan 2007
    Manhattan
    Jeff,
    I just want the focus puller to be able to punch in without disturbing the operator. So ideally the display could happen in both places independantly.
    Ian
    Quote Originally Posted by ibloom View Post
    Yep, as it should be. I guess I just read your original suggestion as you would not want/need it for the EVF at all. Having it independently selectable for any one output would be perfect.
    - Jeff Kilgroe
    Senior Member Charles Angus's Avatar
    Jun 2007
    Toronto
    All good ideas.
    Charles Angus Taylor
    www.charlesangustaylor.com
    Some of the most important/relevant features are being requested right here. Big fan of numbers 4 and 7, especially as possible firmware upgrade features for the R1.
    Birns and Sawyer
    www.birnsandsawyer.com
    Your Vision. Our Gear.
    Camera Sales and Rentals: (323) 466-8211
    Lighting and Grip: (818) 766-2525
    Great ideas Ian !
    A few to add:
    8. Piezo beep when roll and cut. as cool as the Origo is, this feature should be built into the camera. Of course you can turn it off....
    9. Keep TOD timecode over power cycle / battery changes. and / or GPS world clock timecode. Multicam shooting kind of sucks right now.
    Matt Uhry
    www.mattuhry.com
    Hi
    The 1:1 option is great at the moment... however with a 5k camera displayed on a 1k display I would find it too close for live work.. It is cool to set focus (and is brilliant for backfocus adjustments) but for 'on the move' feedback no thanks. It would be just too tight.... 2:1 would be a great option for Ian's suggestions. I personally find 1920 on playback more than enough to 'know' if its too soft..
    At the moment I give the FP an asto with a 1 to 1 button. Even though it is receiving only a 720p signal it works surprisingly well... It would be improved with a live 1080p out.
    All the other suggestions are great 'as is'..
    thanks
    Michael
    Senior Member Mark B.'s Avatar
    I hope it is extremely lightweight and portable! Also, I hope it is energy efficient and subsequently does not require a fan to cool the internals.
