Thread: Monitor
Results 1 to 4 of 4
  1. #1 Monitor
    I found this 1024x600 LCD 5.6" HDMI monitor for 650 USD. I need for my Nikon D90 now, but I would like to use in the future for SCARLET. as we know RED monitors have different input Connectors... so my question is: is it possible to use IKAN for SCARLET?
    Is there any "RED" to HDMI adapter?
    THX
    There is an HDMI output on the RED One. You can get an HD-SDI to HDMI box as well (about $400). Scarlet/Epics will have an output module that should take care of you.
    Interesting inexpensive monitoring solution. I'd be curious to see how it performs.
    I found this other monitor it is just a proto and maybe never comes out, but there will be a smaller one, 8,9".
    "I can't give incredible detail at this moment, as the primary reason we've kept pretty quiet is we don't want to instill false hope or have to take back something we've said, but the new model's PRELIMINARY specs are as follows:
    8.9" diagonal
    1280x768
    Very high contrast ratio
    Super-wide 178 degree viewing angle
    LED backlit - High brightness
    Low-power consumption
    HDMI, VGA, Component, S-Vid, Composite
    1" Thick
    Extremely lightweight - yet extremely durable/rigid anodized aluminum construction (more on this later)
    Multiple 1/4 20 mounts (exact number to be determined) Input welcome
    Custom quick-mount sunhood
    (this info was at dvinfo.net)
    http://smallhd.com/
    it is coming... :) ALU body :) like RED
