Click here to go to the first RED TEAM post in this thread.   Thread: Ask David Mullen ANYTHING
Page 120 of 481 FirstFirst ... 2070110116117118119120121122123124130170220 ... LastLast
Results 1,191 to 1,200 of 4803
  1. #1191
    35mm anamorphic, 8-perf 35mm VistaVision, and 5-perf 65mm are all rather similar, depth of field wise -- generally you choose almost double the focal length to match the horizontal view of something shot in 4-perf 35mm spherical, assuming the same aspect ratio is chosen. So you'd use a 40mm lens in anamorphic, VistaVision, or 65mm when you'd normally use a 20mm lens in standard 35mm, and hence you have two stops less effective depth of field when shooting at the same stop and distance to subject. More or less. You can do the math to figure out the exact FOV issues.
    Roughly, the horizontal dimensions are:
    22mm (standard 35mm sound aperture / RED at 4096)
    24mm (Super-35 gate)
    44mm (effective for anamorphic due to doubling of view on a 22mm gate)
    38mm (VistaVision gate)
    52mm (5-perf 65mm gate)
    70mm (15-perf IMAX 65mm gate)
    David Mullen, ASC
    http://www.davidmullenasc.com
    Junior Member
    Feb 2008
    Hi,
    Could you discuss multiple-camera setups for feature films: are they used a lot for normal coverage, what are the advantages and drawbacks?
    Thank you.
    Senior Member Esmaile Neissi's Avatar
    Dec 2007
    Australia / Irland
    HI david,
    sorry for being off topic, what is the defrence of master primes and ultra primes?
    The main difference is that the Master Primes are one-stop faster than Ultra Primes. They are also a bit sharper with less distortion, have more clarity, but at the expense of being larger and heavier. And more expensive.
    David Mullen, ASC
  5. #1195 Arctic Shooting Advice re-post
    Junior Member
    Hi David,
    This is a question I put in 'off-topic' before realizing it belongs better elsewhere...
    I'm three weeks from a shoot in the Arctic Circle... eventually heading to the North Pole as well as Franz Josef island. The shoot will entail a lot of 'icescapes': bergs, snowpacks, water and skies for a conceptual video art piece.
    I've been told it's an extremely challenging environment in which to shoot--the extremes of temperature, glare, contrast and gods only know what else can make it ridiculously tough, especially if you don't quite, completely, know what you're doing (and that would be me)...
    Any advice on filters, lenses, tips, tricks and incantations would be deeply appreciated.
    I don't have any extreme weather experience, but I'm sure there are others here on this site that do. Main issues I deal with when it gets really cold (I did an HD feature in St. Petersburg, Russia, in December once...) are keeping batteries warm and allowing lenses to acclimate, otherwise they can fog up.
    David Mullen, ASC
    Moderator Tom Lowe's Avatar
    Jan 2007
    To David or anyone here. A couple of high school-level photo class level questions here...
    Say I have a nice 10-second exposure of a night sky at f/1.4 ISO1600. If I put an f/2.8 lens on the same camera, same ISO, how long will my exposure have to be in order to get the exact same amount of light to the sensor?
    Will an f/1.4 lens let in double the amount of light as an f/2.8, or is there some other calculation?
    Also, in terms of exposure times, is ISO1600 exactly twice as "fast" as ISO800? Meaning, if I got a nice 2-second expsoure at ISO800, could I switch to ISO1600 and cut that exposure time to exactly 1 second?
    Senior Member Pawel Achtel's Avatar
    Oct 2007
    Tasmania
    Quote Originally Posted by Tom View Post
    Tom, you have 2 stops between f/1.4 and f/2.8, not one. So, you need 4 times as long exposure time (or sensitivity).
    Edit: this may help: http://en.wikipedia.org/wiki/F-number
    Pawel Achtel B.Eng(Hons) M.Sc
    www.achtel.com
    Sharp to the Edge
    Land and Underwater Cinematography, Production and Equipment | DeepX - the world's only 5k underwater housing for RED Epic and Scarlet | 3Deep - the ultimate 3D underwater housing - available in US and Europe from Band Pro
    Jan 2007
    Thank you, my friend.
    What about ISO speed? Is it literally proportional? ISO400 is twice as "fast" as ISO200?
    Oct 2007
    Tasmania
    Yes, Tom.
    www.achtel.com
    Sharp to the Edge
