Click here to go to the first RED TEAM post in this thread.   Thread: Ask David Mullen ANYTHING
Page 290 of 481 FirstFirst ... 190240280286287288289290291292293294300340390 ... LastLast
Results 2,891 to 2,900 of 4801
  1. #2891
    The most common figure I see thrown around is 15-stops.
    David Mullen, ASC
    http://www.davidmullenasc.com
    Sep 2009
    Oslo, Norway
    I always thought B&W negative film had a few more stops of latitude than color negative film. Maybe it is not a case anymore with the most current color negative filmstocks?
    Another advantage with doing desaturation in post is that you can adjust the individual RGB values for instance if you wanted more contrast/deeper tones in the skies etc. This gives more control than using red/orange filters on the lens.
    REDuser Sponsor Martin Stevens's Avatar
    Jan 2007
    Massachusetts
    Quote Originally Posted by David Mullen ASC View Post
    Thank you.
    Regards,
    Martin Stevens
    President and Founder of Glidecam Industries, Inc.
    Producer and Director at Metaphoric Pictures.
    Jan 2007
    The RED Pro Primes show a certain amount of nisen bokeh (the double lined bokeh you can see for example around some twigs in the second picture of this post).
    Paul Leeming stated that Ultra Primes show the same effect in this post.
    Do you know if this a standard side effect of cine lenses? Do Master Primes, Cooke and Panavision lenses have the same problem?
    Is there a standard procedure to avoid nisen bokeh or at least diminish it?
    Thanks for this wonderful thread, David!
    Formerly known as big lebowski
    EPIC-X #1721 (Stage 3 converted RED ONE #369)
    Quote Originally Posted by Adrian T. View Post
    Adrian,
    I just wrapped on a short using Master Primes and we experienced this 'nisen bokeh'.
    Jan 2007
    ashland, oregon
    Wow film latitude has improved alot over the years. Wasn't that long ago ten stops was a stretch and it took carefull lighting to get three out of video.
    CHUCK
    I'm specifically referring to Vision-3 Kodak negative, which has another stop of overexposure DR over previous generations.
    David Mullen, ASC
    I hadn't even heard of "nisen" bokeh until you pointed it out. I don't see it as a particular problem -- remember, we're talking about moving images, and movement is another element that draws the eye, so I'm not sure how many people are going to think much about the nisen bokeh in out of focus f.g. tree branches.
    The compression of the photos being posted for the internet could be exaggerating the effect.
    David Mullen, ASC
  9. #2899 Helicopter shoot in Nepal question
    Senior Member Yaque Silva-Doyle's Avatar
    Mar 2007
    Los Angeles area
    David,
    I am in Nepal and will be hanging out of a helicopter tomorrow trying to get some decent arial footage with a canon 7D. I wanted to bring my Red cam but it ended up just being to heavy to trek around the himalayas with.
    I guess I just wanted some pointers on how I should mount/hand hold the camera what lens and frame rate I should use.
    we have 18mm Ziess and a 24-70mm L series glass. A couple of bungie cords and some pillows so needless to say it will be a super gorilla style shoot.
    I have thirty minuits in this helicopter with a window open to get these pick up shots for my film Light In The Himalayas so I got to make it count. to get an idea of the look of the film up to this point check out www.lightinthehimalayas.com . Everything up to this point has been shot on the HVX 200 using natural light with as much golden hour as possible.
    Thanks so much for your thoughts, wish me luck tomorrow.
    yaque
    Yaque
    Dos Rios Films
    http://dosriosfilms.com/
    It only ever seems to appear when we're shooting foliage... very odd.
