David it was a pleasure and honor to meet you on Sunday at the Reduser Party. Thanks for all the information.
First thing is to tell yourself that the car is a mirror and will reveal all attempts to light it (unless it is so dirty as to have a matte surface.) You really just reflect things over a car surface more than actually light it, just as you would "light" a mirror. And because the reflecting surface is not as efficient as a mirror, it also darkens what is being reflected into it, the net effect being that if you bounce some lights into a white sheet, for example, though it may look bright and white to your eye, in the car reflection you may see every hot spot, the folds and creases in the cloth, the frame of the white material, the c-stands holding the frame, etc. This is one reason why Fisher lights are so popular for car photography, because it is a neat, clean white softbox with black edges that creates a simple reflection in a car. So you can build your own low-budget version of a Fisher light but you just have to be very neat about it.
If the shot is static, I wonder if you would consider an extreme version of HDR, basically one pass for the sign on the car and a second longer exposure for everything that the sign illuminates, then you can combine them in post to get the sign and what it is lighting in one shot with no additional light. Unless you want some "beauty" lighting on the car, in which case you will have to go with the neat, clean, large softbox approach. Maybe a 12'x20' frame with Full Grid or Heavy Frost, etc. wrapped around the frame itself so you don't see any ties or gaps in the frame (or a black strip all around the hide the gaps) then black shirting all around. Inside should be enough units in a grid pattern to light the material evenly from edge to edge, could be anything, rows of 1K Pars for example, or a lot of nook lights, etc. Or long banks of fluorescent tubes.
Thank you for the reply!
I think I want to put some beauty light on it. The arrow is going to be rather small ( 40" x 20" ) . We wont be able to get a fisher light, but I like the idea of running a bunch of kino's behind a large frame with some skirting along the side, with a smaller but similar setup on the front. perhaps Attached is an sketch that I put together... I think I might have some small amount of light on the car and backlight a bit before the arrow turns on.
Thanks again!
~D
David, we need a little clarification on White Balance with the Epic, I could think of no one better than a pro like yourself. Thanks in advance.
http://www.reduser.net/forum/showthr...156#post992156
Best,
I posted something, but in terms of the actual steps to WB the Epic, there is plenty of advice posted already.
As for grey cards versus white cards, it doesn't matter too much as long as both as neutral and you don't clip any color channels on the white card (which is why some people prefer grey cards.)
Thanks for taking the time to help out David!
Hey David, Were you happy with every script you shot? Did you ever sign on to a project with a script you were not sure was the best work out there or even the best the writer/director can do? Thanks
Sean
Oh, I've done my share of mediocre movies with mediocre scripts... the funny thing is that when you've just finished a job and have some money in the bank, you get really picky about your next project... but as soon as a job falls through and you haven't been working for awhile, suddenly the scripts start looking better! You take jobs for all sorts of reasons, sometimes it's because you want to work with that director or producer, sometimes it's because the premise is interesting or the shooting style or locations are exciting more than the actual script is.
