Click here to go to the first RED TEAM post in this thread.   Thread: Build 18 problems and solutions
Results 1 to 6 of 6
  1. #1 Build 18 problems and solutions
    Senior Member Nir Shelter's Avatar
    Jan 2008
    Sydney Australia
    I must say that so far I have not been impressed with beta 18 3.6. I think that the problem with play back of 4k ANA clips has to be resolved. As it is still a beta release I hope nay pray that they will be resolved for the release... release.
    Is there a way to play back build 18 3.6 4k ANA clips on a MBP core 2 duo, 2.33GHZ, 2GB ram, ATI Mobility Radeon X1600 256MB? All latest software and codec packs have been installed.
    Second big problem I have had with the build is that on output to 720HDSDI we get placed on top of the view area what looks like a 16/9 mask. Noticeable by shaded areas on the side of the video split mon screen.
    Is there a solution for this yet?
    I think I stumbled on a temp work around. The shaded areas are not a setting in the split mon menus and are not visible in the EVF or LCD. When enabling the audio on a shoot the EVF got disabled some how (yes I know but this actually happened) and displayed an error: 'EVF not selected'. As a result of the EVF being disabled the camera re routed the image from the EVF to the split mon similarly to when the LCD is disconnected, subsequently without the shaded mask areas. The DP preferred to use the LCD himself as long as he could show his client a split mon with out those shaded areas. So ever since we disconnect the EVF cable and use the routed image on the split mon for split.
    Nir Shelter - Data wrangler/DIT/AC
    www.datashelter.com.au
  2.   Click here to go to the next RED TEAM post in this thread.
  #2 ANA monitoring
    Red Team Stuart English's Avatar
    Irvine, Ca
    The simultaneous use of RED-EVF and RED-LCD and HD-SDI outputs when in ANA record has been discussed in other threads, and yes you don't get the correct look around on the HD-SDI output in that case.
    A work around is not to use either the RED-EVF or RED-LCD in that application i.e you have three HD-SDI outputs, so use two rather than one of those.
    Other than that what "playback" issues are you alluding to - I'm not familiar with any ?
    Workflow Wizard
    Tim Fassnacht
    www.timfassnacht.com
    Jan 2008
    Sydney Australia
    Thats a shame about the SDI out. The play back issue is that I am unable to playback build18 4kANA clips on my laptop described in my post above. When I try to play the proxy files in QT (codec package V3.5) they play back as corrupt clips and are completely scrambled. When I try to play them back in Redcine (V3.18) the TC turns red and Redcine crashes. But I am able to play them back in Red alert which surprised me only thing is I had a good work flow using the proxy files and separately Redcine.
    I really need these to work.
    Thanks for your response so far.
  5.   This is the last RED TEAM post in this thread.   #5 4k ana
    Irvine, Ca
    Try the latest QuickTime codec on the support page...
    Workflow Wizard
    Senior Member mikeburton's Avatar
    Sep 2007
    Sacramento CA
    Hey Stuart,
    Could you give us an idea about when we could expect a REDCINE update with 4k ana support?
