Click here to go to the first RED TEAM post in this thread.   Thread: 2 Stop faster than bayer cmos/ccd pattern
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 2 Stop faster than bayer cmos/ccd pattern
    http://www.pcworld.com/article/id,13...1/article.html
    Perhaps a version of RED with this novel filter array just announced from Kodak can be used on the Mysterium?
    Kodak are claiming a two stop increase in sensitivity compared to bayer.
    Basically they have a fourth pixel that has no filter and this is used for luminance. Trade off is that there are fewer colour samples.
    Graeme N, can the RED in camera processing be tweaked to work with different filter array or does the in camera processing go hand in hand with RED RAW?
    This idea could also have a use on 3 chip TV camera imagers one chip clear, one green the third with a Red and Blue array.
    Mike Brennan
    Senior Member Stephen Gentle's Avatar
    Jan 2007
    Brisbane, Australia
    I don't know... Wouldn't this knock a lot of data off the colour channels?
    People are complaining enough about the resolution of Bayer sensors...
    Banned
    Quote Originally Posted by Stephen Gentle View Post
    Should not make much difference to the resolution, given enough processing power. Colour resolution will be lower, but not worse than what we already see with 4:2:2 I would guess.
    I was never much impressed with the Bayer pattern, I think it is a relic from when we did not have fast enough signal processors. While I in principle would prefer three dedicated sensors, it could make a lot of sense to replace half the green sensors in the Bayer pattern with unfiltered white.
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    I don't see how this helps though, and the idea has been around for ages - I don't think it's new. I can see how it increases sensitivity, but that's not the problem with any sensor with decent sized pixels, it's dynamic range, and that "white" pixel will just saturate sooner. And yes, you could do an algorithm to guess what's going on in the unsaturated RGB situation, but we can do that already with the standard pattern.
    I can also see it complicating colorimetry and making raw processing harder and bayer demosaicing a lot harder.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    You're probably right and this new design approach will only be for some consumer camera products where speed is valued over color, hence why they are thinking of putting it into cell phone cameras and whatnot.
    David Mullen, ASC
    http://www.davidmullenasc.com
  6.   Click here to go to the next RED TEAM post in this thread.
  #6
    I can see it being for such consumer products, yes.
  7.   Click here to go to the next RED TEAM post in this thread.
  #7
    More info here:
    http://www.dpreview.com/news/0706/07...akhighsens.asp
    So it's not just replacing a green with a white - it's a choice of 3 totally new patterns.
    Graeme
    Quote Originally Posted by Graeme Nattress View Post
    It increases dynamic range because the clear sensors will pick details out of the shadows when the sensors with color filters on top of them cannot, and the color-filtered sensors will give you highlight detail after the clear sensor has clipped.
    I agree that it's not for pros. But one day soon you will have a system similar to Fuji SR where you have a mix of sensors sites of different sensitivities (due to their size, or ND filters, or whatever...). Either that, or current incremental improvements in signal-to-noise ratio / dynamic range will continue to the point where your dynamic range is "good enough". At the moment, it's the main disadvantage of shooting digitally.
    Also, Graeme, I have been shooting some Stouffer tests of my own and am interested - how did you decide on the precise threshold between "I can see a 1/3rd stop of detail here" and "there's too much noise for this to really count"?
    Bruce Allen
    www.boacinema.com
    More info here:
    Graeme
    Thanks for the link Graeme! Looks great. It seem that they are doing heavy noise reduction on the color channels, maybe an intelligent sort of reduction driven by the white-pixel derived luma values?
    A bit similar to what some of you did with your plugins years ago, no? G Nicer would fix the color values, partly informed by the info in the luma, right?
    Bruce Allen
    www.boacinema.com
    Banned
    May 2007
    What if you replaced the bayer color filter pattern with different levels of ND. Could you conceivably design an algorithm that would give you super HDR black and white?
