Thread: avid mxf red workflow
Page 21 of 25 FirstFirst ... 11171819202122232425 LastLast
Results 201 to 210 of 248
  1. #201
    hey Chris
    I'm pretty sure DV only allows a framerate of 25 or 29.97 in the spec.
    that's probably the problem right there.....
    that's why i'm talking about the TC24 column to track back the timecode to the original 23.98 source. It can be done. It used to be done with film/digibeta style transfers so this should be OK also.
    Can I suggest a new thread?
    jamfuze has run it's course (for now...) and "Cutting SD DV for 23.98 Reconform" is much more correct and will enable people who know about this stuff to chime in!
    Don't worry I'll start a new JamFuze thread when it's all available.
    Chris it sounds like you need me to work out the DV offline cutting thing Quick!
    j
    Aug 2007
    Boston
    Quote Originally Posted by Chris Parker View Post
    hey michael. i am trying to put DV25 files i have made through Red Rushes export and then AVID import into 23.976 NTSC formatted AVID project, but the clips, when played, have a timebase of 29.97. I would like to cut in 23.98/NTSC, with these DV25 MXF clips. What I am doing wrong? Go easy, I am an absolute AVID novice...
    The ALE needs to be made in MetaCheater in order to do the TC 29.97 conversion. Once the ALE is imported, highlight the START column and do a CMD-D and select TC24. The values will be calculated back to their original TC24 value. Of course burn-ins will be wrong since they don't take the 30fps TC into consideration. See some of my worklfow docs on www.24p.com
    Michael
    Ernst Lubitsch
    REDuser Sponsor Chris Parker's Avatar
    Jan 2007
    Ok. I got DV25 working at 23.98. I create ALE with metacheater at 1080 23.98. I then put ale into avid bin with project format set to 1080 23.98. Then BEFORE batch importing I switch the project format to NTSC 23.98. Then set my batch import settings to dv25 and import. The new clips come in as dv25 and I can view them proper in a 23.98 timeline. (ie. The timecode matches that in redcine). All thanks to a kind soul BTW.
    I am just looking to confirm that the edl will conform properly later.
    Also....am I supposed to have .mov in the filenames when exporting metadata from metacheater.
    Aug 2007
    Boston
    Yes, you will have the .mov name in the files from MetaCheater. The Name column needs to match for the file import.
    MetaCheater it to be used when creating an ALE as 30fps to be imported into a NTSC 23.976 project since it compensates for the 24 within 30fps world. Switching projects does not do that for EDL creation. Step through the video and look at the START timecode above the monitor - it will be different. Doing the duplicate column into the TC24 will have the wrong starting point for the conversion. You would need to copy/paste each clip on a per clip basis to do a copy without conversion. 30fps projets types of 24fos material is its own thing and mimics the process that has been in place since 1992. True 24fps editing only happens in HD sine HD supports a 24 frame native frame rate and timecode (as well as 23.976 - using the shorthand version of 24).
    One thing to try, is editing at NTSC then flipping the project back to 1080p/23.976 and try an EDL -
    Michael
    Ernst Lubitsch
    Jan 2007
    Quote Originally Posted by MichaelP View Post
    Michael
    michael. you kind of lost me there. i have made an edl with my project settings as they are, and the in and out points seem to be accurate based on the source timecode i check from within REDCine. also, the timecode i see above the monitor is the same as the start timecode in both the 'Start' column in my bin AND the first frame of the same clip in REDCine. All seems to match, so I don't know where my problem is....
    Sorry, but could you explain in more detail what my problem will be with the way I have done things??
    Jan 2007
    ok. so i tried to switch back to 1080p/23.976 and exported an EDL. i am pretty novice at AVID, so I am not sure how to now check to see if my EDL will conform properly when sent to the color facility. is there way i can check this on the AVID? the reliability of the EDL that is.....thanks for the help so far michael....
    Aug 2007
    Boston
    The EDL should match the burn-ins you see in the timeline.
    Michael
    Ernst Lubitsch
    Jan 2007
    i must admit, i am pretty confused about this one. here is what i did, in a step-by-step summary:
    1. transcode .r3d files in red rushes to 640 X 480 with stretch set (editor wanted DV25 anamorphic files to edit with). transcoded into QT, DNxHD 36.
    2. load these transcoded QT's into metacheater.
    3. in settings window, set to 23.98 and hd 1080. did nothing on the main page in the lower right corner (24 to 30, etc. area). saved this ALE.
    4. open media composer. set project to 1080p 23.98. load ALE into bin.
    ***5. switch project format back to NTSC 23.98.
    6. batch import all clips in bin from ALE at DV25 codec.
    7. AVID now makes MXF media. this is useable by media composer and when i play the clips, the timecode display above where the clips play is in a 23.98 timebase, and matches the .r3d files' timecodes in REDCine.
    so...have i done something wrong? will the EDL that is exported by the editor's AVID after the cut is done work properly when loaded into the colorist's suite? is there a better, more rock solid step-by-step that you could give me to get the editor DV25 clips to cut with that WILL work downstream during conform??
    As per Jamie's suggestion, I am going to make this it's own thread.....
  9. #209 jamfuze update
    hello
    there is a new video on
    www.jamieparry.demon.co.uk
    jamfuze now does avid offline STANDARD DEF resolutions
    15:1s, 10:1 and 4:1m have been done
    tested at 25fps and all work fine.
    I *think* 10:1 and others also work fine at 23.976 (wheras i can't figure dv out for americans....at 25fps its fine)
    so you could cut on a low spec system at 10:1 (Which looks surprisingly good out of a mojo onto a Television!) and then jamfuze after an edl to 1080 DNxHD 175X (yes it does 10 bit now!)
    i'll test this properly next week but i think it works.
    DV just wants to be 25 or 29.97 and i can't get my thing to do what i want with the Tc 24 column (grrrrrr)
    so as an alternative 10:1 might be a way for lower spec/home systems to be happy.
    Also done (but not shown) Smokeyfuze online now outputs either 1920x1080 DPX or 2k DPX or 4K DPX with the filenames of the dpx's representing the timecode.
    Right. Hands up who wants to learn some unix for video people? What? Alll of you? Ok.....
    this bit of unix will let you input a frame number and turn it into a timecode-anytime you want.
    You will need textedit to be A PLAIN TEXT EDITOR no rtf or html nonsense. google it and come back.
    OK?
    you'll need a .bash_profile file (which is just a text file) if you don't know what it is you'll probably have to make one. I did because on OS X we don't get a file called .bash_profile by default. We have to make it. In other flavours of unix its there out of the box.
    So to make it
    open Terminal (that is found in Applications/utilities)
    Then type this (or copy/paste whatever)
    touch ~/.bash_profile
    touch is the command to make a file.
    the squiggle (called a tilde) is your home directory and then the file you make lives in there. it's got a dot before it so it will be INVISIBLE (spooooky)
    next in the terminal type or copy this
    open ~/.bash_profile
    this will open the new .bash_profile in TEXTEDIT (which is now a PLAIN TEXT EDITOR RIGHT???)
    copy and paste the stuff below until the end } into your empty .bash_profile file
    tcm() {
    echo "how many frames"
    read framecount
    echo "what frame rate 25 or 24"
    read framerate
    divhours=$(( 3600 * $framerate ))
    divmins=$(( 60 * $framerate ))
    hours=`expr "$framecount" / $divhours `
    remh=`expr "$framecount" % $divhours `
    mins=`expr "$remh" / $divmins `
    remm=`expr "$remh" % $divmins `
    secs=`expr "$remm" / $framerate`
    frames=`expr "$remm" % $framerate`
    hh=`printf "%02d\n" "$hours"`
    mm=`printf "%02d\n" "$mins"`
    ss=`printf "%02d\n" "$secs"`
    ff=`printf "%02d\n" "$frames"`
    echo $hh":"$mm":"$ss":"$ff
    just the above stuff OK???????
    Save and quit textedit
    quit the terminal
    re launch the terminal (this is so it finds your new file)
    in the terminal type tcm
    it will ask you "how many frames"
    you type any number you like
    it will then ask what frame rate 24 or 25?
    you answer
    it will then display the timecode
    you will be amazed that you did this.
    and you can alter it (it's just a text file dude)
    add this lot to .bash_profile and you can do frames>timecode with the command tcf
    tcf() {
    echo "what timecode?"
    read framecount
    echo $framecount > framecount
    frames=`awk 'BEGIN { FS = ":" } ; { print $4 }' framecount `
    seconds=`awk 'BEGIN { FS = ":" } ; { print $3 }' framecount `
    minutes=`awk 'BEGIN { FS = ":" } ; { print $2 }' framecount `
    hours=`awk 'BEGIN { FS = ":" } ; { print $1 }' framecount `
    read framerate
    ff=`expr "$frames" \* 1 `
    ss=`expr "$seconds" \* "$framerate" `
    mm=`expr "$minutes" \* "$framerate" \* 60`
    hh=`expr "$hours" \* "$framerate" \* 3600`
    totalf=$(( $hh + $mm + $ss + $ff ))
    echo $totalf
    and more......
    paste this in to the file .bash_profile (it will be in your "recent" file list in textedit.)
    it will let you rename LOADS of files all in one go i use it to change the extension .MOD to .MPG so my machine can play them
    jren() {
    echo "what do yo want to rename"
    read oldname
    echo "what do you want it named TO"
    read newname
    for file in *.$oldname
    do
    mv "$file" "${file%.$oldname}.$newname"
    done
    save and quit text edit
    quit and relaunch terminal
    type cd then space and then drag the folder where your files are into the terminal window. this is to Change Directory into the folder you want
    type jren
    it will ask you what you want to rename
    you type (for example) MOD (not .MOD don't do the dot)
    then it will ask what you want to change it to
    you type (for example) MPG
    all .MOD will be changed to .MPG
    this works across the network and is free and YOU wrote it!!!!!
    essentially all of jamfuze could be done like this so you set up some defaults somewhere in a text file for things like where the R3D files would be,where you would want them to go etc etc this would be the same for a 6 week shoot.
    you could type "rushes"
    and jamfuze would do the rest.
    cool huh?
    just givin somethin back.
    Stuart Cunningham has been helping me and I think he wants me to teach people to fish not just give them a salmon.....
    cheers
    j
    Aug 2007
    Boston
    The resolutions you refer to doing are interlace data rates. If shooting progressive, you should be creating 1:1, 2:1, 3:1, 14:1, 28:1, or 35:1 as the JFIF codecs as well as the DV progressive based ones.
    Michael
    Ernst Lubitsch
