Thread: FCP sync&drifting problem footage shot on RED 23.976/audio DAT
Results 1 to 2 of 2
  1. #1 FCP sync&drifting problem footage shot on RED 23.976/audio DAT
    Junior Member
    May 2009
    There are many discussions touching on this but after trying out a number of things I am still stuck.
    I am doing a sound mix of a project in FCP shot on the RED/23.976.
    Sound is from DAT 48/24bits currently, not sure whether this was changed in any way.
    I exported OMF to Soundtrack Pro when I import the finished mix its out of sync by 0.1%.
    To work out what the problem was I exported the clean audio directly from FCP as aif and then re-imported it straight in, again having the out of sync problem. So it must be a FCP issue?
    When I adjust the speed to 100.1 &of either the Sound there is still a very slight out of sync problem.
    Is this the best I can do, are there any other options to fix it?
    I was going to settle on the speed adjusted audio - but this will be put on HDCSR and they want the audio as separate wavs - again this would invite syncing problems.
    Any ideas?
  2. #2 Workaround
    Senior Member Snow R. Shai's Avatar
    May 2008
    Tel Aviv
    You can always export your separate .wav file from the final rendered, sound-fixed master QT file...
    Snow
    Director_editor
    Snowdrum Audio Visual
    www.snowdrum.com
    Twitter, Vimeo
