Thread: Logging Footage in a FCP Environment
Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1 Logging Footage in a FCP Environment
    Junior Member
    Jul 2009
    On a feature film at what point is the footage logged so that the AE can organize the project and dump the clips into the scene bins for the editor? I seem to get a lot of different answers to this question and surely it varies from project to project.
    I know that a lot of big features backup the footage then send the drive to the lab and the lab does the log and transfer; but what is the best practice for logging clips (and transcoding) if we wanted to do it ourselves and use the lab only to finish. I consulted Red on this, but wanted to get some feedback from someone who has been in the trenches (especially any pitfalls or garbage in, garbage out experiences).
    I know that an AE can log and transcode, but I was wondering what the difference is in workflow between a low budget and medium/large budget feature. Is this the responsibility of the AE or does the data wrangler or ninja handle this? And what is a ninja and why does he make so much money? ;) If the data wrangler (or ninja - forgive me for my ignorance) does the transcode to Pro Res on set for the offline edit, and the pro res is delivered to the editing room what is the best way to log the clips?
    I guess the question also comes down to - how does one man the cutting room?
    Thanks for helping me wrap my head around this new workflow!
    Eva
    Mar 2009
    Burbank, Ca
    On low budget indies I data wrangle, transcode and asst edit. I take the camera drive home, back up the raw camera files to 2 external drives (real ones, not MyBooks or LaCies) at the same time with Shot Put Pro, than hook each drive up to separate MacPro towers and use RedRushes to transcode to whatever flavor of ProRes or DNxHD the editor/post house wants. Then import the transcodes into FCP (or export an ALE out of RedRushes and batch import into Avid), sync sound if needed, create master clips and scene bins, and at the end of the shoot hand everything off to the editor. The workflow is a little more complex than that, but that's the basics.
    Junior Member
    Jul 2009
    I'm in the process of using Redrushes right now to transcode R3D media. One question I have - once I bring the newly transcoded footage into FCP to organize, can I safely change the file names within FCP to reflect scene/take without fear of losing their connection to the original R3D files?
    Junior Member
    Jul 2009
    Thanks! By real drives, would you say Buffalo or GRaid? Do you log during your transcode, or is that what you mean by create master clips? In which case, how do you do that (subclip?) I come from the telecine world in which the AE has a flex file and batch digitizes, so I am concerned with about the metadata, etc with the Red, and how wacky subclips are for an editor in FCP. The guy at Red said that if we use the FCP log and transfer, we could change the file names and later conform to the R3 media with no problem. Is that true with Red Rushes? I suppose my question now is the same as maho.
    Thanks, again!
    Eva
    Mar 2009
    Burbank, Ca
    I would never change any file names, you just put the clips into bins which you can name anything you want. You and the editor should test your workflow in whatever color correcting environment you plan on using to make sure everything links back to the R3D's. Bear in mind, though, that there are perfectly acceptable CC alternatives that involve staying with your original transcodes that eliminate the need to go back to the R3D's.
    Creating new master clips for the editor to cut scenes with involves selecting (apple-A) everything in the timeline and drag-drop it back to whatever bin you want the master clips to reside in. The camera settings (metadata) stay with the R3D's, and can be modified in RedAlert which generates an .RSX file which stays in the folder with the R3D's and the camera proxies.
    Not sure what you mean by "log during transcode" - define "log".
    Finally, the basic rule is, stay away from cheap drives. I use Avastors and have never had any problems, whereas I just had a brand-new Western Digital My Book the producers bought without my approval die on me on day 2 out of the box! GRaids are also good, although really the Raid 0 config a Graid uses is better suited for editing, not backing up and transcoding, since the added bandwidth of Raid 0 is not needed.
    Junior Member
    Jul 2009
    Thanks, Joe. By logging I mean using the slate information to label clip like the telecine operator does. On the big pictures I have looked at, this was done by the lab. The guy at Red said that in FCP you can change the file names and the metadata stays intact. As an editor, I have always had scene bins with all my takes labelled which match the script notes, camera reports, etc. With this new workflow, I want to understand how to get to that point. I think we have established the Pro Res offline with a conform to the R3. I did a test run by logging and transferring my dailies and changed the file names to match the slate. The new media on the scratch disk has the identical timecode as the mag proxy Quicktimes, so if understood the guy at Red and the metadata is indeed intact, I imagine this should work.
    I can't even imagine editing with the file names that come out of the Mag, but maybe I am missing something here, so I appreciate your input before we get started and make a costly mistake.
    And I so know that pitfall of a Western Digital drive. Ouch!
    Aug 2007
    Boston
    Speaking for an Avid workflow, you can change names to human loving ones to make the editor happy. :)
    All relevant source metadata is tracked in other columns. You only need it the first time you do the ALE to QT merge. I keep a dailies bin of my original transcode, then I create scene bins where I copy the files (not move them) and change the name to my heart's content. Since these are only pointers, it still points to the original files from the dailies bin. Should a drive die or a file get deleted by mistake, I do a batch import from the original bin with the original files and everything relinks automagically. :)
    Michael
    Ernst Lubitsch
    Junior Member
    Jul 2009
    Avid is my next workflow challenge. Thanks for the tips; I think that I have a FCP workflow that's similar. I will let you know how the test pans out.
    Junior Member
    Jul 2009
    Okay. So I ran a test and logged and transferred to Pro Res. During this process I changed each clip name to it's slated info (41_1) then I edited together a sequence. I then used media manage to create an offline. I opened the offline project, loaded the master clips into log and transfer window and got a message that told me what Mags to load. I mounted the mags which came in with their original file names, even though the master clips had new names, so it seems to me that the metadata is maintained and read despite the file name change and I can re-transcode just my sequence if I wanted to go to Pro Res HQ. My assumption (although I hate to assume - and would love someone to set me straight) is that this would be true if I wanted to go back to the original R3D files.... Could I hand off the sequence (EDL? XML?) to the lab and would they be able to conform and cc?
    And how about timecode and the Red..... What should I look out for there?
    So many thanks!
    Mar 2009
    Burbank, Ca
    Quote Originally Posted by Evadiva View Post
    That is the real question, everything else is just playing around in FCP Media Manager...you have to run a test with your workflow where you export an EDL/AAf for the post house and see what happens. On the project I am currently on, we tried an AAF with renamed master clips on a Pablo and it failed, then I switched the names of the master clips back to the original camera file names, and the AAF linked back to the R3D's.
