Thread: Workflow options since FCS3 release
Results 1 to 2 of 2
  1. #1 Workflow options since FCS3 release
    I am posting a Red feature using 2K ProRes workflow. All proxies are generated from the Log and Transfer window. The original intention after picture lock was to do our color grade on a Scratch system using the XML export process to finish in 4K
    Since FCS3 was announced and there is now native 4K support in Final Cut Pro and Color, this raises some new questions for us regarding our original post workflow.
    - Should we consider ProRes 4444 for our finishing rather than onlining with R3D as originally intended?
    - Since the Log and Transfer window gives you the option of batching in the "Native" Red footage, is the resulting Quicktime now 4K in FCP 7? The "Native" setting produced a 2K QT in FCP 6, right? And since the QT is a wrapper around the original R3D media, the process of batching "Native" per the Red whitepaper on FCP workflow should now allow for a 4K color grade in Apple Color, correct?
    - If we online with ProRes 4444, do we risk sacrificing some of the latitude with altering the image that we would have otherwise had by manipulating the R3D media?
    - The new version of Cinema Tools now offers the ability to import R3D clips and treat them like film rolls that correspond with transcoded footage in the timeline. If we go with an R3D online workflow in Color, will we have to use Cinema Tools and re-batch all of our footage so that Color links back to the R3D?
    Thank you so much for your insight and answers to some or all of these questions.
  2. #2 4x4
    Senior Member Snow R. Shai's Avatar
    May 2008
    Tel Aviv
    Hello,
    First off, FCS3 has just come out, and requires thorough testing. There are various results on the RED forums, and i believe more time is needed for more info. Naturally, I would fully test the workflow you need to make your big decisions. Test it for yourself.
    That said, ProRes 4x4 goes up to 12-bit [RGB or Y’CBCR sources] and should be virtually lossless with 4x4 color space. Great for RED mastering. Read the ProRes white paper from Apple - sounds good on paper.
    Color 1.5 should be able to master to 4K DPX or 2K ProRes 4x4.
    I have been using the ""native"" L&T workflow in FCS2, finishing in Color, with 2K ProRes HQ and got great results. This should work in 4K now.
    Some new tests i saw in the forum had varied results.
    Anyone that can render a full quality 4K out of Color 1.5 - please let us know. I will be finishing in 2K anyhow...
    As for Cinema tools, i don't believe you need it for RED workflows. Color will link to the original R3Ds automatically, same as in FCS2.
    Snow
    Director_editor
    Snowdrum Audio Visual
    www.snowdrum.com
    Twitter, Vimeo
Tags for this Thread
View Tag Cloud
