Thanks Brad!
Thanks Brad!
thanks for the update
Is the lens data issues/issues addressed here? Perhaps that happened in the last version and I was not cracking out properly on reduser and missed it....if so forgive.
Been testing this for some days now, and works very good. Soon time for a stable 20 ;)
Ok, False Color seems much more accurate. My spot meter lines up within 1/3 stop of tolerance.
I'm guessing from the Keslow chart that purple false color would be considered black. I don't find any usable detail in IRE 1-2.
I'm using a Pentax Digital Spotmeter, Its kinda old... Probably could use a calibration. But it seems to match up anyway. I do have it set to 320 ASA, and I'm lining up within tolerance. I'm surprised,
I'm putting the Straw Color, (+2 stops above 18%)--- on White (I'm saying the 85% white field, I'm using a Kodak Chart). Or just under 1 on my spot meter. 18% is within 1/3 stop tolerance(43 IRE). the Skin tone Color is 2/3 stop above 18% (Just as Stewart said). Thats also within Tolerance, 1/3 of a Stop, Not too shabby..
I did get different results when referencing 18% gray. It would have said sensitivity of sensor is around 160, thats why I referenced white instead.
I assumed the same for the purple color being pretty much Black.
How are you trying to adjust those, as they work fine for me...For some reason I cannot change the user settings now on the back three user menu buttons. Side buttons work fine, but the back three are set at ISO, Color Temp and Shutter. Any clues for the clueless?
The user buttons work for me too, Hold button for three seconds when inside desired Menu
