Thread: Build 20 = higher frame rates?
Results 1 to 8 of 8
  1. #1 Build 20 = higher frame rates?
    Before yesterday I couldn't get more than 30fps in Varispeed mode configured at 3K 16:9 under build 18, 17, etc.
    Yesterday after changing to the latest build, 20.1.2, all of a sudden I had access to more than 30fps, infact I could crank it up to 50fps. Momentary insanity or was this feature always there and I didn't know how to access it?
    Either way, I'm happy.
    Senior Member Brandon Fraley's Avatar
    Bay Area, Ca.
    pretty sure it was always there :)
    Brandon Fraley
    Director - Cinematographer
    EPIC-X #2762 "Zoë"
    Mar 2008
    From Red.com, the camera "provides 4K (up to 30 fps), 3K (up to 60 fps) and 2K (up to 120 fps) capture."
    Always like this
    cheers
    J. Eric Camp
    600 DIT | NYC
    Senior Member Raphael Varandas's Avatar
    Jan 2008
    Sao Paulo - Brazil
    Yeap always like this to me too...
    Regards
    DCINE
    Cinematografia Digital
    www.dcine.tv
    www.vimeo.com/dcine
    www.facebook.com/Dcine.Digital.Cinema
    2x RED 1 MX
    2x EPIC M
    1x EPIC X
    2x SCARLET
    5i set coming
    Leica set coming
    atendimento@dcine.tv
    raphael@dcine.tv
    SAO PAULO / BRASIL / 55.11.55498419
    Member Maxim Penev's Avatar
    Dec 2008
    Sofia, Bulgaria
    I had the same bug.Build17, 8gb CF, 3k, 16/9, 35fps and as soon as i pressed the rec key "Frame rate too hi".After a reboot everything get normal again.
    What speeds do your cards provide? I seem to remember that the Red is quite demanding on IO-speeds of the CF-cards... so maybe the framerate is capped by the card and not by the camera or its firmware build?
    Senior Member Dominic Jones's Avatar
    Jan 2007
    Brighton, UK
    Were you shooting 29.97? If so, you most likely had "open gate" enabled in the VF settings - that will limit your framerate options in varispeed...
    Just a thought,
    Dom.
