Thread: Digital Cinema Package
Page 48 of 50 FirstFirst ... 3844454647484950 LastLast
Results 471 to 480 of 491
  1. #471
    Quote Originally Posted by Wolfgang Woehl View Post
    Avi, maybe you want to start with Chris Perry's basic and excellent tutorial (http://bitfilms.blogspot.com/2010/11...en-source.html).
    Also, there are a number of open source toolsets related to digital cinema so you'd need to be way more specific to allow anyone to help here.
    Which tools? What are you trying to do? What are you actually doing?
    Hi
    I am following these steps:
    http://www.stereofinland.com/?page_id=49
    Avi Liani
    Oct 2008
    Munich
    I pushed some code to collect and check X.509 certificates for Digital Cinema/SMPTE compliance upstream. Checks are following DCI_CTP_v1_1.pdf, chapter 2. See dc_crypto_context.rb.
    These certificates, as you know, are used to sign DCPs and KDMs (See make-dc-certificate-chain.rb for PoC code to generate some of those certificates and Cinemaslides to actually use them.)
    Junior Member
    Apr 2010
    Quote Originally Posted by Avi Liani View Post
    need a little help.
    I am trying to learn making DCP with open source.
    So I downloaded all open source tools. and I have uncompressed tif sequence, but when I run convert to DCP. bat file or image_j2k bat file, I get that it does not recognizes file type.
    What may be the result?
    Hi
    If you get "unregonized filetypes" error when trying to encode from tiff to j2c, it might be because your tiff image isn't in a correct resolution or bitdepth.
    Can you provide some more information regarding your files... Are they 1998x1080, 2048x858, 2048x1080 or 1920x1080?
    Or maybe provide which exact error you get. Screenshots or copy/paste of the error.
  4. #474 Can anybody help?
    Junior Member
    Jun 2010
    Yakutsk, Sakha Republic, Russia
    I have problem at ppm to tiff conversion stage
    Code:
    FOR /F %%i IN ('dir /B "%DIRNAME%\processing\01-pics\left\*.ppm"') DO  %IMDIRNAME%\convert "%DIRNAME%\processing\01-pics\left\%%i" -type  truecolor  -alpha Off  -depth 12  -gamma 0.454545 -recolor "0.4124564  0.3575761 0.1804375 0.2126729 0.7151522 0.0721750 0.0193339 0.1191920  0.9503041" -gamma 2.6  "%DIRNAME%\processing\02-transformed\left\%%i.tif"
    More close to black, brightness changes stepwise.
    On upper half - original picture, in lower half - after conversion by ImageMagick:
    What is it the?
    Let's try to fly without drinks and drugs!
    Oct 2008
    Munich
    Bert, can you post an original ppm and your tiff result so we can try to reproduce?
    Junior Member
    Jun 2010
    I have put files here: http://turbobit.net/mxegs5m6p8rp.html
    Oct 2008
    Munich
    Bert, well, I can't reproduce (IM 6.5.7-8 here) what you're getting. The IM line you're using is fine. Also, although the linearization part is of the often used approximating type instead of the costlier correct type it wouldn't crush low values that much. Don't know, maybe your IM version is nasty. I'm sure over at ImageMagick Users someone might be able to pinpoint it.
    Junior Member
    Jun 2010
    Thanks, Wolfgang! The brother a wolf was right - upgrade to last version ( 6.6.9-5) has helped. People, don't use version 6.5.9-2 of ImageMagick.
    And what the "correct type of the linearization part" must be?
    Oct 2008
    Munich
    Bert, see http://en.wikipedia.org/wiki/SRGB#Th...transformation for the reasoning behind the math. In short gamma encoded sRGB carries a small linear range (values <= 0.04045 [0,1]) and a powered range (values > 0.04045, powered by 2.4). The resulting slope can be approximated with a 1/2.2 slope but this will crush low end values.
    ImageMagick will do the right thing when called with "-colorspace sRGB".
    hello
    I've built a new (beta, untested) smpte and interop xml subtitles generation tool, from the text generators found inside a Final Cut Pro timeline.
    http://www.michaelcinquin.com/tools/...DCP_subtitling
    I would appreciate field feedback.
    cheers
    Michael Cinquin
    Final Cut Pro - Avid Media Composer editor
    Davinci - Baselight - Color colorist
    www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode - Keycode calculator | YOU
