Will Red be able to change the power-off button functionality, so that it requires confirmation of power down?
I have seen a few people ask for this now, and I hoped it would be in Build 20. But it isn't.
It is far too easy to accidentally press the black button :-(
We looked into that as a potential upgrade. Unfortunately it's not possible to implement via firmware.Will Red be able to change the power-off button functionality, so that it requires confirmation of power down?
damn with the power down button... done it several times... think every one has? - sound ready... camera... and camera got powered off- with DP swearing and cursing....
Yes it does. When you upgrade to build 20 toggle the S4i in the menus and wait a few seconds and the lens data will appear on the screen.
You can boot up the camera having the Birger power cable in the aux port with out any problems. At least in my case, haven't had any problems in powering up the camera. Notice that if there's a failure in the lens data, you won't get the lens data back without rebootiing. So, if you don't get the lens data after upgrading, switch the S4i option on and reboot while keeping the Birger power cable connected to the camera.
I would like to test the camera after installing the new build.
Which kind of test I have to do in your advice?
thanx
Upgraded to build 20 and the Birger lens data works perfectly. Thanks again Lauri. Think I'll go shoot something now.
