Click here to go to the first RED TEAM post in this thread.   Thread: RELEASED: Release Build 20 Firmware (v20.1.3)
Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 51 to 60 of 75
  1. #51 Feature request
    Senior Member JanneJansson's Avatar
    Aug 2008
    Sweden
    We've been running 20.1.3 for 3 days now, and the only problem I have seen is "SATA error" during playback one time and during record one time. I changed the battery and restarted the camera and no more problems.
    I have a small feature request:
    To be able to route audio inputs to more them one audio track. Then you can have a hi gain on one channel and a low gain on the second channel as bakup.
    ..and I think Redalert is behaving wrong if you shoot using RAW view mode, and then make a adjustment in Redalert and then re-open same file, the adjustment is double applied.
    JJ
    Senior Member jimhare's Avatar
    Sep 2007
    Sydney Australia
    Having great success with 20.1.3. Shot 5 cameras for 2 nights straight and only had a single issue with a single camera.
    At the end of a 70 minute take (proxies definitely OFF) it just locked in POST for about 15 minutes, after which we had to cut the power to prepare for the next show.
    We got everything except the last R3D, which is obviously corrupt, so it plays fine, just cuts off a few minutes early.
    Is this more likely to be a drive issue or camera issue?
    Everything else perfect so I'm extremely happy with the reliability.
    Senior Member Pawel Achtel's Avatar
    Oct 2007
    Tasmania
    The look, colours and image quality are georgious with the new build. Simply stunning. Yeah, one hickup with my camera on the shoot , but otherwise, as Jim said, smooth sailing and great footage.
    Pawel Achtel B.Eng(Hons) M.Sc
    www.achtel.com
    Sharp to the Edge
    Land and Underwater Cinematography, Production and Equipment | DeepX - the world's only 5k underwater housing for RED Epic and Scarlet | 3Deep - the ultimate 3D underwater housing - available in US and Europe from Band Pro
    Sep 2007
    Sydney Australia
    Just looking at your camera from last night now Pawel, those Master Primes certainly sing!
    Only lost the last couple of minutes of encore, but we have it from four other angles, plus the night before so we are well and truly covered.
    Senior Member Curran Giddens's Avatar
    Jan 2007
    Berkshire County, Massachusetts
    Quote Originally Posted by jimhare View Post
    If you turn off the "Make QT Proxies" option, that issue won't ever happen. Also, you may be able to recover those last few minutes using RedUndead.
    http://www.SolarSystemStudio.com/
    EPIC-M #508, EPIC-X #124
    Sep 2007
    Sydney Australia
    It was turned off. Post should have taken a second or two. We are sending the log file to Stuart to have a look at.
    Jan 2007
    uh oh. I hate that post bug. Hopefully Stuart will be able to squash it once and for all....
    Sep 2007
    Sydney Australia
    Me too. Luckily it only happened once. For the second show we intentionanally shot for an extra 10 minutes after the end, so if the post issue happened again, and we lost the final R3D, it would be well after the end of the show. Was fine though, didn't happen again.
  9.   Click here to go to the next RED TEAM post in this thread.
  #59
    Red Team Deanan's Avatar
    Jan 2007
    REDundead may be able to pull out the last missing R3D.
    Jun 2007
    Quote Originally Posted by Stephen Webb View Post
    And a reation is..?
    A softer reaction, of course.
    -sc
