I've had this question for a while... has anyone else experienced a bug with Build 17 cameras where you format the drives in R3D Data Manager and reset the reel number manually on-camera, only to download later data and find that the camera chose a different reel number than the one you set?
I'm curious to see if anyone else has had this problem; if so, how do you fix it? Was this a bug that was solved with Build 18? 19? 20?
