Thread: RED QuickTime Reference files in FCP?
Results 1 to 10 of 10
  1. #1 RED QuickTime Reference files in FCP?
    Junior Member Matt Reyer's Avatar
    May 2009
    Roanoke, VA
    I've read the white paper on FCP workflow and I still seem to be missing something, so please bear with me. If this is covered in another thread then just redirect me.
    I understand that the QuickTime reference files are not ACTUALLY QuickTime movies, but just refer to the .R3D and ignore a certain amount of pixels.
    So I can import these reference files into Final Cut and edit them, but when it comes time to export my movie, then will the size be 1k (if i use the 1k ref. files), 2k (if i use the 2k ref files), and so on?
    I edit with the ref. files because my computer cannot handle full blown 4k. Right? Editing 1k just makes the process quicker. How can I edit 1k ref. files and export the timeline to a full quality 4k movie?
    Senior Member Alex Carr's Avatar
    Aug 2007
    Send to Color and export, yes it's that easy if edited off Proxies
    Union 600 DIT
    Apple Certified Pro FCP 7
    Red #778 'Leonardo'
    Digital FX Greg M's Avatar
    you could replace the proxies with the full proxies or expert an edl and conform the project on a online system like Scratch, Smoke, Clipster, etc.
    digitalfx.tv
    The RGBlog- Ramblings about Cameras, VFX, etc.
    Twitter
    Red One #83
    Epic-M #98 and #240
    Epic-X #83 and #116
    Junior Member
    Sep 2009
    Quote Originally Posted by Matt Reyer View Post
    Log and transfer to proxy ProRes
    Edit in FCP
    reconform with cinema tools or clipfinder
    open in Color 4K
    Grade in Color 4K
    Export to 4K dpx, cineon or anything
    May 2009
    Roanoke, VA
    In FCP, how exactly do I "reconform" or replace the proxies with the HQ clips with the edits in place? What is the menu option?
    What is "clipfinder"? Never heard of it.
    Senior Member nima's Avatar
    Apr 2008
    New York City
    Ok Matt, this is the best way to kill a thread.
    It looks like you should do a little more research. If you are a visual learner (like most of the filmmakers) you can take a look at some helpful videos:
    this is a general explanation of the entire workflow: http://blip.tv/file/582829
    here something more specific for your case (click on video links):
    http://www.michaelcinquin.com/tools/red
    here is some concise explanations of Clipfinder: http://www.daun.ch/software/Clipfind...ingafinal.html
    Junior Member Patrick Inhofer's Avatar
    Oct 2009
    New Jersey
    It's all laid out in the Whitepaper. In the FCP 7 version of the Whitepaper go through Workflow 2.
    The first few times you'll need that Whitepaper open while following the step-by-step process.
    Essentially you need to Media Manage your locked picture to a target RED preset you need to build following the White Papers instructions. You'll be creating an OFFLINE sequence that references nothing.
    Then you go back into Log and Transfer, set it up as laid out in the White Paper, add all the volumes on which your source R3Ds reside, and then Batch Capture the OFFLINE sequence you created with the Media Manager.
    Your R3D files will now be copied, wrapped in a QT wrapper, and then you'll have a sequence referencing the R3D files and ready to be sent to Color.
    That's it!
    No one said it'd be simple. But follow the White Paper, step-by-step, and all is good.
    HTH
    - pi
    Senior Member ChrisLyon's Avatar
    Sep 2007
    Shreveport, LA
    Where's Ian when you need him? Check out Crimson Workflow if Clipster, etc aren't available to you. It provides an alternative proxy replacing solution.
    Chris Lyon
    Shreveport, LA
    Editor/DIT
    Scarlet-X #1180
    Hey Patrick,
    Welcome to the boards!
    www.urbanmouse.com
    RED#1277 "Jean Grey"
    EPIC#898 "Logan"
    2013 REEL
    Unless you have RED ROCKET. I seriously recommend not editing with proxie files (which correctly should be called reference movies).
    Do yourself a favour and follow the workflow recommended here.
    http://reduser.net/forum/showthread.php?t=35308
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
