Thread: Evf - Viewfinder Button Broken
Results 1 to 5 of 5
  1. #1 Evf - Viewfinder Button Broken
    Junior Member
    Sep 2009
    for what is the "big" Evf - Viewfinder Button
    Sounds/Feels like my is Broken....?!
    It's supposed to be quite "loose" actually. Never quite understood why. I took the lid off and put a small piece of gaffers tape inside the knob which makes it nice and snug.
    Tony Lorentzen, Kinema Follow me on Twitter: kinemadk
    Freelance RED Tech, DIT & Workflow wizard, Partner in VBag, Owner of RED EPIC-X #420
    Member David Barlow's Avatar
    May 2009
    Southampton UK
    Under Setup/Display there is a check box for the EVF menu. If this is checked you will get a menu on the left of your display in the EVF only. If you cannot see it try pressing the large button in once and you should see it as you can turn it off even when checked! You can then rotate the button and a cursor will allow you to select an item from the list. Pressing the button again will select the item and then rotating the button allows you to alter it. I find it really useful for making quick adjustments without taking your eye from the viewfinder. More details on page 77 of the operations guide. (Build 20 or 21). The button does feel loose as Tony says but you should be able to feel a soft clicking as it is an encoder and will turn continuously in either direction.
    Junior Member
    Sep 2009
    WoW....thats it! it works and now i can control the shutter fast&easy :-)
    thanks a lot guys!!!!
    Nov 2007
    London
    Thanks for the tip David.
    I wondered why I couldn't see the menu.....this could have been explained better by Red in the manual...like so many things ;)
    BTW p77 of the my operations guide v20.0.0 doesn't mention the EVF at all - it's about audio ouptuts.
    Having tried out the menu it seems a shame that I can't see what I am changing any of the settings to, unless I look on the rear status display.
