Thread: Redmote question
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1 Redmote question
    As I understand it, the battery in the Redmote isn't user-replaceable. Does that mean the unit would have to be returned for a new battery? Or is it more likely that it's not easily user-replaceable?
    Nothing is impossible if you don't care about a warranty.
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
    Senior Member Gerald Menclik's Avatar
    May 2009
    Vienna, Austria
    Quote Originally Posted by Dave Barak View Post
    could be recharched when attached to the brain, maybe .... as anything around here at the moment - just guessing
    menclik.at
    pre-production-post
    Vienna, Austria, Europe
    The later you brake, the longer you're fast .......
    Senior Member Brad Webb's Avatar
    Jan 2009
    Los Angeles, CA
    I'm sure you won't have to replace the battery but once every few years, so it's not like it'll be that big a deal.
    Scarlet X - 643 "Kong"
    DP Reel
    www.digitalladder.com
    Senior Member Pietro Impagliazzo's Avatar
    Mar 2008
    Rio de Janeiro, BR
    Quote Originally Posted by Brad Webb View Post
    Not for people live near RED authorized service centres.
    It'll be a big deal for me and lots of international customers.
    What's so bad about user replaceable anyway?
    Acintyah khalu ye bhava na tams tarkena yojayet
    There's no use arguing over that which is inconceivable
    Pietro Impagliazzo
    vimeo.com/impa
    impagliazzo.500px.com
    I'm pretty handy with a screwdriver and a soldering iron, so if the battery is something that's commonly available, I wouldn't have a problem replacing it on my own. That is, of course, if the case isn't permanently sealed.
    Does anyone know what type of battery is being used? Just curious.
    Jan 2009
    Los Angeles, CA
    Quote Originally Posted by Pietro Impagliazzo View Post
    To make it small enough I think they had to put the battery in a place that made it not user replaceable.
    You could always buy or rent a 2nd REDmote while yours is in the shop.
    DP Reel
    Mar 2008
    Rio de Janeiro, BR
    It's not like the RED Mote size is such a critical factor.
    Make it an inch thicker and let us replace those batts!
    I'm sure it won't have to become a brick to allow us that.
    Pietro Impagliazzo
    vimeo.com/impa
    May 2009
    Vienna, Austria
    That's the point Pietro! As I'm living in Austria I have the same concerns. Where's the problem to build it recharchable? Not much bigger, needs only mini plug and we're goin' ..........
    menclik.at
    pre-production-post
    Moderator Martin Weiss's Avatar
    Mar 2008
    mostly Norway
    Just to put this discussion into a perspective.
    I am using my laptop every single day, been using it for over a year now. Been using my iPhone for almost three years now, charging it pretty much 1 - 2 times a day (heavy use).
    In other words: unless you are going to use your Redmote 24/7, there will be quite a while before a battery replacement becomes necessary - if ever.
