Click here to go to the first RED TEAM post in this thread.   Thread: SATA out on REDDRIVE
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1 SATA out on REDDRIVE
    Junior Member
    Jul 2007
    I just went through the FAQ and started to think about my ordered REDDRIVEs the moment I realized that there is apparently no way to get data out via SATA, since the connector is a proprietary part with the REDONE and the REDDRIVE offers FW400/800 instead as outs.
    Will there be a way to have an adaptor for the REDDRIVE SATA connector?
    It would be far more efficient - when transferring, editing and backing up data - to have a REDDRIVE connected to a SATA Express card or a preconfigured workstation RAID, instead of using FW400/800.
    Could this be an option, or are there any obstacles by soft-/hardware design in the way to have this?
    Best regards
    Boris
    not sure that's correct -
    I know the connection to the camera is proprietary - but I thought there was FW400/800 AND SATA connections on the other side of the drive for offload - now I can't remember ...
    Stuart?
    FireWire 800/400, USB-2 and e-SATA interfaces
    Quote Originally Posted by PaulClements View Post
    That's what I remember from NAB - can we get a RED confirmation?
    Stuart -
    can you tell us what the sustained READ speed of the drive inside current REDDRIVE is?
    Quote Originally Posted by offhollywood View Post
    Stuart -
    How about you Paul...anyone, anyone..?
    Hope this helps,
    http://www.reduser.net/forum/showpos...24&postcount=3
    The RED DRIVE and RED RAM digital magazines both have a mini-phono jack connector for external 12V D.C power, so in the case of an e-SATA hook up to your computer you would only need to create a LEMO to e-SATA cable.
    At this point in time though, the speed of available hard disks or flash drives is still lower than that of FireWire 800, so there is no apparent advantage to this idea.
    __________________
    Workflow Wizard
    Discussed before on these threads:
    http://www.reduser.net/forum/showthread.php?t=2547
    http://www.reduser.net/forum/showthread.php?t=3288
    Actually I have a feeling USB2.0 might have been removed, not too sure. The ones I listed are infact on red.com but I have a feeling there have been changes since then and simply not updated.
    eSata should be 2400Mbit/s (300MB's), firewire 786Mbit/s (98.25MB/s) and USB 2.0 480Mbit/s (60MB/s) - These are not confirmed by Red, just what you should expect from each delivery format. The speed of the hdd in the redrive will probably be slower than esata though.
    Unfortunatel I am not aware of changes to the USB2 and quite frankly that wouldn't be too intelligent to remove that one as there are PCs out there completely unaware of IEEE1394.
    I am also interested in the pin-out of the Lemo-cable. I assume it might be a few percent faster, but in the end shouldn't make a remarkable difference. The SATA interface speeds in general are of no real interest, because as you mention already Paul
    its exactly like that: No 2-disc drive combo out there currently touches the headroom of SATA2 speeds. FW is 100MB/sec. and thats probably the maximum of what the little raid is able to deliver (as of current laptop drives, disregarding the performance of the raid DSP inside, which might limit the throughput anyway and wouldn't be too unusal for this special/small appliance).
    I wonder if the RED-RAM stripe set could be faster than FW800s 100MB/sec, making the use of an Lemo to SATA adapter very interesting again. But I seriously doubt the controller inside goes beyond that.
    If RED uses the same DSP than LaCie in its Little Big Drive, I'd assume it maxes out at 80-90 MB/sec.
    Heres a test for the interested at Barefeats.
    RED DRIVEs have USB2.0, FW400, FW800 and DC power connectors. The DC power is there in case the drive is being connected to a system that doesn't supply bus power over the USB or FW interfaces -- many PC notebooks do not, they only have a 4pin (not-powered) firewire port.
    Additionally, there is a proprietary LEMO connector that carries eSATA and power on the same cord. To connect to a system via eSATA, one would have to create a custom LEMO to SATA cable with the proper pin-out. Not sure if RED is going to make a wiring diagram available or if they will even provide such a cable. I'm sure that someone will do it.
    As for drive speed, both USB2 and FW400 are plenty fast enough for the current model RED DRIVE. There will be no speed gains by going to eSATA. The RED RAM is a bit faster though -- I think, or at least faster transfer times have been mentioned as a benefit. But we're not sure how fast.. I highly doubt that a current model RED RAM will be able to saturate a SATA connection or even strain a 100MB/s FW800 interface.
    - Jeff Kilgroe
    Jeff for those of us who are pretty computer ignorant does what you say above mean that firewire 800 will download the mag. in about 1/3 of real time? (27MB second recording rate 100 MB second firewire 800 out to portable raid)
    TJ
    www.camera-person.com
    TJ Williams
    Seattle WA USA
    206 769 8585
    RED1, 4K Sony HD (HDCam) Panasonic HD
    Operator Dp, Videographer
    Steadicam Camera Crane Aerial mount
