Thread: Export Looks from RedCine-X
Results 1 to 6 of 6
  1. #1 Export Looks from RedCine-X
    Senior Member geoffboyle's Avatar
    Nov 2007
    It varies daily
    Hi Guys,
    Does anyone know how I can export looks?
    It's looking like a great piece of software.
    If I can pre-grade looks and export them as I can in Iridas SpeedGrade for other systems I'd be happier than a pig in shit!
    I'm with Geoff. This would be a big deal for me. At the moment it seems as though looks are stored within the app, not as separate files. Can anyone confirm / clarify? Is this connected to the announced 'FLUT' feature of the new line of cameras?
    Richard Bradbury
    Focus Puller
    London, UK
    Junior Member Dan Boyd's Avatar
    Jan 2010
    Greater Detroit Area
    I'm just trying to save the meta data so the next time I open Red CineX the clip remembers what I adjusted. Also it would be good if when I log and transfer to FCP the grade I adjusted would be applied. is this currently possible or should this be a feature request?
    Is there a clear and solid workflow already established for Red CineX?Thanks for any help
    Oct 2007
    Quote Originally Posted by geoffboyle View Post
    Hi Guys,
    Id also like to know if I can do this and how.
    thanks,
    Dave
    RED mentioned that exporting looks to Cam is on its way, but not currently enabled... as I understood it.
    Sidney Lexy Plaut
    filmmaker.
    Epic Package. Complete set of rehoused Cooke s2&3 series 2000... and lots of toys.
    www.vimeopro.com/sidneydp/sidneydp
    You can generate a look file with REDCINE -X now. It will create an RLK file but if you used FLUT science in your look or REDCOLOR and REDGAMMA then that will not translate.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
