Thread: RED with NIKON Adapter
Results 1 to 6 of 6
  1. #1 RED with NIKON Adapter
    When using RED with the $500 RED Nikon f-mount adapter will there be any light loss or is does it simply convert the PL mount to a NIKON mount?
    Thanks in advance.
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    Senior Member Zakaree Sandberg's Avatar
    orange county/los angeles
    light loss? Its not a 35mm adapter like the redrockmicro or mini35 if thats what your thinking..
    Its a nikon mount that replaces the PL mount
    Zakaree Sandberg
    Zakaree@Gmail.com
    Cinematographer / Local 600 DIT
    RED MX - 1015
  3. #3 answered
    Yes,
    I thought so but I was just double checking. Thanks for the quick reply.
    David
    So it replaces the PL mount? Can you have both PL and Nikon adapter ring?
    Senior Member Dominic Jones's Avatar
    Jan 2007
    Brighton, UK
    You can indeed (in fact the R1 ships with a PL mount, so if you order a Nikon F then you'll end up with both anyway). There's some speculation over how easy it will be to accurately change the mounts, however, and it may end up being necessary to have the mount changed by a qualified and correctly tooled-up (not in a Ray Winstone sort of way!) camera tech in order to ensure correct flange focal depth - we just don't know yet...
    Jan 2007
    ashland, oregon
    battistella,
    Just want to make sure you understand that the Nikon mount is not an adapter ring in the sense that it mounts to the Arriflex PL mount. It's a completly seperate mount that attaches to the front of the camera in place of the Arriflex mount. If you already know this I'll shut up. lol
    Chuck
    Quote Originally Posted by chuck colburn View Post
    battistella,
    Chuck
    Yes,
    That is what I understand. At first I thought it would be a bit easier to interchange RED and NIKON lenses but I understand it is not a matter of adding this to the PF mount and putting a NIKON lens on. It's a more complicated venture than that.
    coolio.
    David
