Click here to go to the first RED TEAM post in this thread.   Thread: November 30th Announcement Feedback
Closed Thread
Page 112 of 144 FirstFirst ... 1262102108109110111112113114115116122 ... LastLast
Results 1,111 to 1,120 of 1434
  1. #1111 2/3" DSMC ???
    Senior Member Patrick Grossien's Avatar
    Nov 2008
    Germany
    Quote Originally Posted by Joseph Ward View Post
    Will the new DSMC have HDR for Motion and Time-lapse?
    Well the announcement was "HDR stills ..." so it'll probably be that way - for now. ;) As time lapse is nothing else than stills that should be possible depending on the time sequence.
    Talking about stills: One thing that i can't quite get my hands on is: how does the 2/3" compare to dslrs stills wise. I know it will be a mind blowing cinema tool. But stills? The quality will be more than cool as seen in some stills jarred shot a while ago but the size just might not be. As for the sensor size it compares to the canon g9-11 power shots. So it will probably not be sufficient eg for magazine shoots.
    Like to hear what you think. And don't be coming: get a 1D or medium format for stills :) I would just like to know what to expect.
    Or any official statements from RED ? scarlet s35 was the smallest to get the DSMC name branded to the specs. so does that mean the 2/3" is not seen as a full dsmc - I know it does support both.
    Thanks for helping me clear that one out!
    /p
    SCARLET-X "Mathilda"
    "Life is full of obstacles. They never end. The ones that get past them have the richest life."
    jim jannard
    "if your pictures aren't good enough, you aren't close enough."
    robert capa
  2. #1112
    Senior Member Jeff Coatney's Avatar
    May 2007
    Fushun, China
    Quote Originally Posted by David Doko View Post
    I presume most of you are kidding about the turrets, but to squash the fun -
    Turrets introduce an additional layer of mechanics that require a lot of maintenance over time. And as Axel Broda kindly showed me on my Arri SB, turrets can introduce small flange focal distance errors without proper calibration, they can throw your focus off a bit. Luckily Arri made the very solid turrets on the S and SB. Still, single mount systems will always be more reliable and accurate.
    David, I agree with you about unnecessary mechanical parts. Its the primary reason I oppose the OVF program. However, with regards to the lens turret, the development tools available to the Red engineers are more than capable of providing the tolerances and solutions necessary to avoid the problems you cite. SolidWorks, for example, provides an environment where these solutions can be simulated, refined and revised before it goes to steel. A turret can be designed that can not only provide the primary function, it could also self-calibrate the taking lens position. The rotational axis of a lens turret can have a bit more wiggle room than a spinning mirror on the OVF (which requires massive calibration to prevent it from lying to your eyes). I think a turret can be implemented relatively easily. But its design would require a developmental process. But, in the end, I think it would result in greater sales volume for those mini primes.
  3. #1113
    Senior Member Justin O'Neill's Avatar
    Jan 2007
    San Diego/LA/Seattle
    Quote Originally Posted by Patrick Grossien View Post
    Hi Patrick, the 2k mode of the RED One gives us an approximation of what to expect from the 2/3" Scarlet. Here are some 2/3" TIFFs I shot on the RED One @2k:
    http://www.reduser.net/forum/showthr...796#post505796
    The 2/3" 3k resolution and the quality of the miniRED primes means Scarlet stills should be considerably sharper.
  4. #1114 150 fps burst
    I have a question about the 150 fps burst if anyone from RED can answer. Assuming that the highest bandwidth storage system available is being used, how long of a 150 fps burst can be captured? Also will it be possible to ramp up to 150 fps?
  5. #1115
    Senior Member Jeffrey T. Morgan's Avatar
    Oct 2007
    Michigan
    112 pages read! been taking my time, reading everything:
    1. As someone who was kind of negative with the lack of info last month, I feel obligated to say I am SUPER stoked since Nov 30th. This is simply amazing across the board (at the risk of sounding gushing). And the cameras will be arriving (barring any "red owners first, then slow roll out") 6 months before i realistically thought.
    2. "Bomb" is bad, sorry. I almost didnt get into China because my camera was Japanese (Canon). The guard / customs kid was being a real tool, and the others told him to stop in Chinese (didn't think I understood) but honestly, he was CLEARLY looking for any reason to keep my camera from leaving the airport, which would have cost my client over 30k in wasted tickets and time. I know it seems extreme, but that's the world, and while i TYPICALLY don't worry about overly sensitive people, if I am trying to save orphans or feed my family with my work, I avoid issues that hinder me. So if it says BOMB, i will scratch it off the moment I buy my first plane ticket.
    ... what about BIZZOMB? or BOMBIZZLE? :-P
    3. people have been saying the fixed is a great deal even at 4x the cost. Someone also said "the competition, cameras under $10k..." ... SCARLET is way way better than that. Tell me if I am wrong, but dont the high speed 2/3" HD cameras start around $220,000 (no glass)! They often go over 120fps, but they are still just HD, and not really portable... (gasp, i just said "just hd"! i work so hard getting smaller clients to understand why SD is a BAD idea.)
    4. Red Mini Primes are a god send. I am hoping for a modest Red 2/3" ZOOM for regular work, and getting the interchangeable with a zoom and a few mini primes. If not, I may get the fixed with a $2,000 1.6x extender and $500 wide adapter.
    5. I had thought the 2/3" would be a DSMC too... guess i was wrong because I dont think of 5mp as acceptable any more, though that other link is compelling. but 3k is 3k, so that's the resolution, right?
    6. Jarred, you have been awesome. Not condecending, lots and lots of great answers. Fueled my RED fire again for sure! same for the rest of red team chiming in.
    7. I have a big job next May, so Scarlet will be coming out of that, unless it hits before, then I will buy it FOR that job. (and keep my workhorse XHA1 as a poor mans b-cam, cause it really is a great cam.)
    8. any idea how to adapt a 1/2" canon HD eng type lens with a SONY mount to a 2/3" scarlet? lol... no, really.
    9. as to crop factor, i have spent the last 30 days looking into Scarlet glass (before mini primes were launched) and I am NOT SURE the resolution coming through the 2.5x or 4x crop on your 35mm glass is high enough for 3k... but i am not an expert... somewhere in between now.
    10. Thanks again for everything red team.
    Jeff
    www.PrometheusMotionPictures.com
  6. #1116
    Senior Member Stephen Gentle's Avatar
    Jan 2007
    Brisbane, Australia
    Quote Originally Posted by Jeffrey T. Morgan View Post
    I really doubt that this will be a problem. The item will already have been x-rayed, so it will be clear that it doesn't contain any explosives (given that apart from the circuit boards, display panel and lenses, it will mostly be empty space). If they're still worried about it, they'll do a 20 second explosives residue test on it and your bag, eliminating any concern at all. I've heard of stupid airport security officers, but I doubt anyone is that much of an idiot to hold you up on that.
    Besides, why would they think that it was a bomb anyway? It's really small, and if something was a real explosive, it would have a warning label on it saying (in Australia) something like 'Class 4.1 Dangerous Good - Combustible solid'. You could have it labelled as an explosive, but it'd never say 'bomb'. And, if you were actually trying to smuggle an explosive on-board an aeroplane, I assume that it would be unmarked and hidden...
    Really, I doubt it will be a problem.
  7. #1117
    May 2007
    Fushun, China
    Red Gunner. Bomb EVF. Lens Turret. I wondered what was up when I saw a Polish Mortar Round on Jarred's desk. Hmmm...
  8. #1118
    Feb 2008
    Atlanta, GA
    First post after having been a Red voyeur for as long as I can remember (def. pre-Red One) And now 112+ pages of Nov 30th Announcement and feedback.
    I can honestly say, I have Scarlet fever.
    (andrew hollister)
  9.   Click here to go to the next RED TEAM post in this thread.
  #1119 Audio Inputs
    Red Team Stuart English's Avatar
    Irvine, Ca
    If all brains have 2 built-in mini-phono audio input jacks, will a brain with a base I/O module attached have the two channels of XLR input from the I/O plus the 2 mini-jack input for a total of four simultaneous recording channels? Or does the addition of an I/O somehow override the mini-inputs?
    In that scenario it's four total audio channels...
    Workflow Wizard
  10.   Click here to go to the next RED TEAM post in this thread.
  #1120 HD-SDI outputs
    Irvine, Ca
    Will the HD-SDI outputs follow industry 'standard' in the PsF vs P?
    i.e.
    1080/29.97PsF and 25PsF
    1080/59.94P and 50P
    720/59.94P and 50P
    No to PsF, i.e. yes to 1080P at 23.98 and 25.00 and 29.97
    Workflow Wizard
