Click here to go to the first RED TEAM post in this thread.   Thread: November 30th Announcement Feedback
Closed Thread
Page 132 of 144 FirstFirst ... 3282122128129130131132133134135136142 ... LastLast
Results 1,311 to 1,320 of 1434
  1. #1311
    Senior Member Jimmy Odom's Avatar
    Aug 2009
    Chicago, IL.
    Quote Originally Posted by Gavin Greenwalt View Post
    You would pass up a camera which can shoot:
    2/3", S35 or FF35 for a camera which can only shoot 2/3"?
    Sensors are like haircuts. You can always trim but you can't add. Get the largest sensor you can afford/fit. It'll offer the most flexibility.
    Very eloquently stated.
    Go BIG, or go HOME!
  2. #1312
    Senior Member Justin O'Neill's Avatar
    Jan 2007
    San Diego/LA/Seattle
    Quote Originally Posted by David Mullen ASC View Post
    I don't see why the equivalent depth of field of shooting 35mm at around an f/5.6 is an "ENG aesthetic". Who decreed that the only acceptable f-stops to shoot 35mm at were f/4.0 and wider?
    Exactly David. I think there were other problems with the images on 2/3" cameras in the past and the deeper depth of field got blamed. I have seen gorgeous images with shallow DoF on the RED at 2k with a nice Angenieux lens at t2.2. I think people are going to be pleasantly surprised with the 2/3" Scarlet.
  3. #1313
    Junior Member
    May 2008
    New Orleans
    Précisément! Or, just for instance, this search turns up plenty of gorgeous photos that could easily be stills from a film. (Assuming APS-C is roughly equivalent to 35mm motion picture film.)
  4. #1314
    Aug 2008
    Quote Originally Posted by Michael Hastings View Post
    I think that isn't correct. If I am not mistaken the bayer pattern has two pixels with green filters for each red and blue filtered pixel. So besides whatever loss there is in the debayering algorithm (which affects red blue and green), you automatically have half the red and blue color resolution.
    Which mimics the color resolution of the human eye very closely. Most 3 chip video cams also sub sample red and blue at half the green sample rate or less. You have to get to HDCAM SR 4:4:4 to get full color sampling.
  5. #1315
    Aug 2008
    I would rather have 3k resolution at 2/3" than 2k when most of the time I would be shooting 2/3"/16mm format with wide range compact zooms anyway. The extra DOF and compact optics of the smaller format are a plus for me. Not to say I wouldn't love to have an FF35 Epic with a full complement of RED electronic lenses though. However that is not in the budget.
  6. #1316
    Jul 2009
    Quote Originally Posted by Tom L View Post
    Of course, there are other advantages to larger sensors aside from DOF. First and foremost is superior image quality.
    Right. If DOF were the only concern, then an $80 Kelly wheel and the will to use it (or a $2 iPhone app) is a better solution than replacing your entire camera package.
  7. #1317
    Senior Member Michael Hastings's Avatar
    Florida
    Quote Originally Posted by David Rasberry View Post
    true but it isn't inherent in the design as with bayer
    Save the Sharks
    __________________
    Red #206/Epic-X Stage2 Now shipping Epic U/W housings - accepting orders - contact us. U/W housing for REDONE - for sale or rent. Check out our new Aero3D™ mirror/beamsplitter rig. 954.937.6600 www.Aquavideo.com ... aquavideo1 at yahoo.com
  8. #1318
    Well, a RAW Bayer image not exactly the same thing as recording a 4:2:2 signal due to the debayering algorithm, which can make intelligent guesses as to the color of nearby photosites and thus compensate to some extent for missing information.
    Ultimately what matters anyway is how well a camera sensor or sensors can separate red, green, and blue information with a minimal amount of crosstalk which reduces saturation and color purity. The resolution of those separate channels after recording and post processing is sort of a separate issue.
    David Mullen, ASC
    http://www.davidmullenasc.com
  9. #1319
    Mar 2008
    New York City
    does jim said anything about the RedOne sensor upgrade?
    Will be before or after the scarlet/epic release?
    g
  10. #1320
    Senior Member Peter Moretti's Avatar
    Apr 2008
    And FWIU, three chip designs do a much better job of separating colors than single sensor mask designs. It has to do with the type of material used for absorbtion for the filters vs beam splittig for the prisms.
    But single sensor designs don't have the deep back focus requirement that three chip designs have, so cine and still lenses can be used.
    1110001100010102
