Click here to go to the first RED TEAM post in this thread.   Thread: November 30th Announcement Feedback
Closed Thread
Page 35 of 144 FirstFirst ... 253132333435363738394585135 ... LastLast
Results 341 to 350 of 1434
  1. #341
    Member ScottyC's Avatar
    Nov 2008
    Pittsburgh, PA
    Quote Originally Posted by Stephen Strangways View Post
    At the risk of temporarily veering off-topic...
    Considering that Final Cut still insists that perfectly good MXF-wrapped footage has to be re-wrapped into Quicktime wrappers, which takes time, doubles your storage space requirements, and prevents you from playing those files on a computer that doesn't have Final Cut installed... I think it's safe to say that Apple's current policy is to only support Quicktime MOVs, and make anyone shooting AVIs, MXFs, or R3Ds jump through extra hoops.
    Yep... they have really disappointed me lately. They stopped focusing on the professionals who made them what they were and put their attention on the average consumer. Thankfully, RED hasn't fallen for this. I will drink a beer to that!
    By over-estimating your problems, you under-estimate your ability to overcome them.
  2. #342
    Quote Originally Posted by Brent J. Craig View Post
    -with the addition of a compass/accelerometer chip - the camera could tag every frame with the direction the lens is pointing and the tilt angle (crucial for CGI work).
    I highly doubt that the precision would be enough for VFX matchmaking needs for final compositing. However, data stream may be OK for realtime rough 3D composite preview while shooting on-set.
    Yannick Sadler
    "The more perfect a thing is, the more susceptible to good and bad treatment it is."
    Dante, Divine Comedy, 1321 A.D.
  3. #343
    Senior Member Eren Ozkural's Avatar
    Dec 2007
    London/Istanbul
    Previous frame "onion skinning" in the Epics only? Boo! Hiss! Sorely missed...
    Well, you gotta stop SOMEWHERE before you make Scarlet the perfect camera and cannibalise your Epic sales ;)
    KINOTRIGGER
    Feature Films, Fashion Films, Photography, S3D, Pre/Post/Production.
    VIMEO YOUTUBE TWITTER
  4. #344 REDRAY Pro questions...
    Junior Member
    Sep 2009
    Tucson, AZ & San Francisco, CA
    Jarred,
    Quote Originally Posted by Jarred Land View Post
    * Optional media and local link encryption
    * 4 x USB-2 ports
    Are you referring to 802.1AE MAC (link layer) encryption (like what's found on Cisco's Nexus 7000 data center switches), or just classic IPSec? Also, will PKI tokens or smartcard readers be supported via USB? I could see movie studios wanting this feature, especially if mainstream cinema deployments are one of your target markets. Imagine sending a first-run film via DVD through FedEx, but having the disc be worthless unless the recipient holds a valid Fox/Paramount/Universal issued PKI token. I'm sure you guys are thinking along these lines, yes?
    * Decode .RRD (RED RAY Distribution format) 4:4:4 files up to 4K @ 30 fps
    Any chance of choosing a file extension type that does not conflict with Tobi Oetiker's RRDtool Round Robin Database files? How about RRT (RedRay Transport)? And, no, I didn't check to see if 'RRT' was being used by anything mainstream...
    -ian
  5. #345
    Senior Member Quentin Brown's Avatar
    Nov 2008
    UK, London & East Anglia
    I second the question about servo controlled zoom. Is this there or a currently planned option on the fixed or any of the REDmini primes?
  6. #346
    Will RED be making mini-zooms to accompany mini primes? I thought I was done buying lenses, but these suckers are re-igniting my inner lens junkie.
    So much good stuff happening, it will take time to absorb it all.
    Can you set an EPIC next to the Nikon and the SCARLET? Or are the brain boxes all the same size? Will there be size/weight differences between SCARLET and EPIC, assuming no modules?
    This is the most innovative imaging company on the planet, bar none.
  7. #347
    Aug 2008
    Quote Originally Posted by Peter Osinski View Post
    david, are there other lenses made with a mini pl mount that you know of?
    if so when buying my 2 angenieux arri mount zooms would it be possible just to get them converted to mini pl and save myself the trouble of 2 mounts when I can afford the mini primes?
    The mini-PL style RED mount is unique to Scarlet as far as I know. Not to say there won't be after market lenses for it within a year or so. Modified versions of some B4 HD lenses from Fuji, Canon, and Angenieux with rear optical elements suited for a single focal plane sensor camera would be pretty easy and quick to design for the Scarlet market.
    There is an ARRI B mount to C-mount adapter available from Chambless cine that might serve as an alternative to a more expensive PL conversion for 16m lenses. I am considering this route vs PL conversions for a couple of my lenses.
  8. #348
    Nov 2008
    Also how about that lovely OLED display on the lens design you showed us last time round. Is that coming across the the fixed or REDmini's?
  9. #349
    Senior Member Peter Osinski's Avatar
    Jun 2009
    Washington DC, USA
    Quote Originally Posted by David Rasberry View Post
    I plan on buying a an adapter ring from whitehouseaudiovisual.com for 400 for each of the 2 zooms I plan on buying which are the 12-240 and 9.5-57. They are very big lenses and I want a robust mount.
  10. #350
    Not to dash anyone's hopes but the sort of GPS receiver I would expect on the scarlet/epic is not going to be per-frame. Most GPS receivers are about 5fps. Not that it really matters since you probably won't move outside of the receiver noise in one second anyway.
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
