Click here to go to the first RED TEAM post in this thread.   Thread: November 30th Announcement Feedback
Closed Thread
Page 60 of 144 FirstFirst ... 105056575859606162636470110 ... LastLast
Results 591 to 600 of 1434
  1. #591
    So I am getting my Scarlet fixed lens for my birthday! It is fixed and I am 8x excited!
    Milan Nikolic :)
  2.   Click here to go to the next RED TEAM post in this thread.
  #592 REDCODE RAW via Ethernet
    Red Team Stuart English's Avatar
    Irvine, Ca
    If I understand the specs, can one capture Redcode via the Gigabit Ethernet connection directly to a PC?
    To clarify -
    You record to the camera media first, then you can copy that file (or files) over Ethernet.
    Workflow Wizard
  3. #593
    Jun 2009
    New England
    Quote Originally Posted by Stuart English View Post
    To clarify -
    Whooooaaaaa
  4.   Click here to go to the next RED TEAM post in this thread.
  #594
    Quote Originally Posted by NBS Studio View Post
    Can anyone at RED answer...
    Can I upgrade the LCD on the 2/3" Fixed Lens Scarlet from the 2.5" to a more comfortable 5" touchscreen LCD?
    yes.. :)
  5. #595
    Atlanta, Georgia
    Jarred,
    Thanks for the pics and info, nice work. The 2/3" cinema looks like my camera of choice at the moment (please post about the B4 option).
    I do have a question. The Mini-Primes have the "focus and iris" rings reversed.
    I have used the Canon EC primes and they have the same feature. My guess it helps with the "breathing" during focus pulls.
    I did have a slight problem, getting my Chroiszel follow focus in so close to the camera body for hand-held work-it was impossible with the Canon lenses, there was not enough room for the focus arm and gear, because the focus ring was on the inside not the outer part of the lens.
    Will the Arri, Chroiszel or other manufactures be able to use their follow focus' for hand-held work?
    My experiences show primes are very "tight" with rotation-this could be a bit difficult on the finger tips.
  6. #596
    HDR Mode isn't bracketed stills. I guess my midnight brainstorm was a premonition. :D
    So how does it work? Does it use the max frame rate of the sensor to build up a composite? Or some clever sensor side trick?
    Will there be a tool for easily extracting R3D metadata into a chan file or similar? I suppose I could do it in Nuke but I would rather not have to. Just a little cmd line tool to drag and drop an r3d and spit out an XML/Chan/CSV file would be appreciated.
    How raw is the accelerometer data? Does it come out in estimated world units or is it just raw acceleration data int he meta-data and require processing SDK side to be posXYZ/rotXYZ or Quat? If the latter will we have the option to have the rotational data in Quat?
    Gavin Greenwalt || im.thatoneguy
    im.thatoneguy[at]gmail.com | Straightface Studios | VFX & Animation
    Canon Scarlet-X package available to rent in Seattle, WA
  7. #597
    Senior Member Jerrod Cordell's Avatar
    Jun 2008
    Cape Canaveral, FL
    Quote Originally Posted by Jarred Land View Post
    PL mount is standard on S35 EPIC and S35 SCARLET cameras.
    Mini-PL standard on 2/3 Removable. Sorry for the confusion Peter.
    Ooohhhh, so I take it the mini-RED Primes are not electronic?
    And damn Jarred, do you ever sleep? lol.
    Jerrod Cordell
    Angry Leprechaun Productions
    Watch my shit!
    http://www.Angry-Leprechaun.com
  8. #598
    Aug 2007
    Quote Originally Posted by Lorenzo Straight View Post
    What a huge size difference between the Scarlet and Nikon. It's amazing how you guys were able to pack so much power into such a small package.
    yes, in that configuration it's smaller which is nice for some applications but there's no way you're holding it comfortably like that. once you add on the bits that make it more comfortable to hold they should be closer in size.
  9. #599
    http://www.redgrabs.com/up/1259705913.jpg
    Awesome.
    First there seems to be a tab to open up more on the left. There are two icons in the lower right that would appear to me to be battery related. Just curious what the outside one is. Looks like a cool down timer. Yes, I'm that geeky.
    I am very excited things are changing fast.
    So will the FLUTS replace our current monitoring luts (709, Redspace) or will they work in conjunction?
    How many different LUT's can be working? One to the client monitors and one for on boards? Two for on boards? Just curious.
    cheers
    J. Eric Camp
    600 DIT | NYC
  10. #600
    Senior Member Ben A.'s Avatar
    Sep 2007
    Hi Jarred,
    Can you tell us what the difference is between the Pro remote and regular remote?
    Thx
