Nope. Not true. DOF is primarily a function of focal length in relation to aperture. Other factors do play a role, such as the distance to your subject and the circle of confusion within the optical path. CoC remains fairly constant if we retain the same sensor/film properties and and lens mount (focal depth). Smaller sensors have deeper apparent DOF because they require shorter focal lengths to achieve the same field of view as a longer focal length on a larger sensor (or image area).
You can see the DOF effect (or lack thereof) produced by a smaller sensor simply by cropping into an image. Shoot 4K on the RED One. Then switch to 2K and shoot the same shot two different ways. First change the lens to a different focal length to achieve the same framing, then using the same lens as with 4K reposition the camera to achieve the same framing. Compare your DOF.
But everything else you wrote is pretty much spot on. It's just a common misconception that sensor size actually has a direct effect on DOF. I think a lot of people are far too concerned with DOF and how to achieve shallow DOF, especially on a 2/3" sensor. Many Hollywood films are shot on 2/3" cameras these days and no one seems to notice.
Here's a quick example. It's a goofy example in that it's shot 3K, so between 2/3" and S35 frame size, but fairly wide focal length and moderate aperture.
Hello Jarred,
Is possible time code in and out like redone under Scarlet with fix lens?
Thanks!.
1st time poster...long time lurker!
Thanks to the Red Team, price for the fixed looks great!
Hope I can sell my HVX kit for something reasonable now that this announcement has come out. Maybe someone who is unhappy with the price increase will snag it! $3K for 720p! Ooooooooh the 60p slomo is so nice! ....anybody?
-Dane
Shoot.Cut.Create
Is there an specs on the Still image resolutions of Epic or Scarlet? How many Megapixel equiv are we talking? Anything close to a phase one back or more along the lines of 35mm.
Wow, just saw the UI image in the announcement thread. Love it.
With either one of the optional I/O Modules, yes.Is possible time code in and out like redone under Scarlet with fix lens.
looks like the new UI image would be for the touchscreens. Is it safe to assume that if using the EVF you would have to have the redmote to access all the menus and options? would the evf look similar to that UI image as well (as far as the information and histo goes)?
Yes, that's correct. That's a tab that opens up for selection of various UI options.http://www.redgrabs.com/up/1259705913.jpg
Awesome.... there seems to be a tab to open up more on the left.
Yes, either a REDmote or a Side Handle.Is it safe to assume that if using the EVF you would have to have the redmote to access all the menus and options?
Yes, it would look very similar.Would the EVF look similar to that UI image as well (as far as the information and histo goes)?
