22. 3-axis internal motion sensor and GPS latitude / longitude data
In addition to the lat/long will the gps time also be recorded? Is this data recorded on a per frame basis? Is red willing to disclose what rate sensor part is they are using so we might be able to get some more detailed specs on it? Is the lens data also recorded (focal length, focus setting, aperture, etc)?
23. True Shutter Sync In/Out and Genlock
By 'True Shutter Sync', does this mean that when we trigger the camera externally (from ttl signal?) that the entire frame begins integration at the same time or is there any sort of rolling shutter (electronic or otherwise)? Does the Sync In trigger the start of integration or does the duration of the pulse also determine the integration time (i.e. do we have external realtime control over integration time)?
Are these various capabilities applicable to all the scarlet/epic cameras? Are these capabilities built into the brain or some other module (e.g. Pro I/O)?
