Thread: Offline/Online on Media composer for HD finish
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Senior Member Rainer Fritz's Avatar
    Vienna
    Quote Originally Posted by person View Post
    And when for the MAC?
    In my opinion we dont need it. IF you have a Rocket. With Rocketcine you can render out in realtime final MXF container.... just relinking then.... with an ALE you get more metadata in....
    http://www.k-effects.com
    Postproduction - Workflow Service - VFX - Animation
    Quote Originally Posted by MichaelP View Post
    It's not part of the next MetaFuze, but top of the list for the follow on release. The MetaFuze in Jan/10 has RSX support, original filename to Tape, new color space, REDROCKET hardware support, 720p/25 and a few other things I can't think of off the top of my head.
    Michel
    I'm going to begin rendering MXF's and start editing the new feature film very soon. Is there any way to perhaps betatest the new metafuze? I'm in a frustrating situation where I probably need both real filenames and 720 25p support.
    How limited am I with the current version of Metafuze? What are the online possibilites? Is it only workable with Avid DS as the online suite?
    Aug 2007
    Boston
    email me please a michael (dot) phillips (at) avid...
    Michael
    Ernst Lubitsch
    Nov 2007
    London
    REDcine needs certain metadata to do the loading of the construct. If the path name has changed anytime from the original ALE created from REDcine, then it won't work. cineXML does a re-index and creates a new REDcine XML.
    Michael
    I'm pretty certain the path is exactly the same - the original r3d files are still in the same place.
    The original ALE was created in Clipfinder - could that be the problem?
    nigel
    Aug 2007
    Boston
    Yes, the step by step guides says that the ALE needs to be created from REDcine as well for that roundtrip to work. cineXML will be the solution for the re-indexing and XML modification to make it work.
    Michael
    Ernst Lubitsch
