Click here to go to the first RED TEAM post in this thread.   Thread: POSTED: Build 21 Firmware (v21.4.1) - Release Version
Closed Thread
Results 1 to 2 of 2
  1.   This is the last RED TEAM post in this thread.   #1 POSTED: Build 21 Firmware (v21.4.1) - Release Version
    The latest release version of RED ONE camera firmware has been posted on www.red.com/support - Build 21 RED ONE Firmware, v21.4.1 (password-protected).
    SUMMARY:
    * Addition of 4.5K WS (Widescreen 4480 x 1920 pixel) RESOLUTION recording setting.
    * Addition of REDCODE 42 QUALITY setting for 4.5K WS, 4K 2:1, 4K ANA, 4K HD record resolutions.
    * Addition of VIEW mode indicator, vmRAW / vm709 / vmRSP, in upper GUI status row.
    * Addition of video Genlock for HD-SDI PVW output(s) when GENLOCK selected in SENSOR menu.
    * Addition of support for Cooke prime and zoom lenses (Cooke v2.29 firmware or later)
    * Addition of REMOTE PORT selection and LENS PORT enable checkbox to REMOTE menu.
    * Adjusted area metered by RGB clip meter to active recorded area only.
    * Adjusted area metered by RAW sensor meter to active recorded area only.
    * Adjusted resolution of SHUTTER PHASE control from 5 degree to 1 degree steps.
    * Changed Edge Highlight color from red to blue to improve visibility.
    * Bug affecting MASTER GAIN setting in VIDEO / COLOR menu fixed.
    * Bug affecting flip / flop of REC709 and REDspace VIEW during camera playback fixed.
    * Bug affecting Toe X and Toe Y reported to GUI in TONE menu fixed.
    * Bug affecting Time / Date reported to GUI in SET TIME / DATE fixed.
    * Bug affecting monitor path in 4.5K WS mode (two short vertical lines in GUI) fixed.
    * Bug affecting monitor path in MAGNIFY mode (tearing outside active video area) fixed / mitigated.
    * Bug affecting adjustment of Ch1 / Ch2 Volume from USER KEYS fixed.
    * Bug affecting adjustment of Ch1 / Ch2 Volume from RED-EVF menus fixed.
    * Resolved boot error condition affecting certain cameras.
    * Resolved loss of POST message at conclusion of record pass.
    * Verified Image Magnify function lock-out during record.
    * Resolved 4.5K WS position error when on-camera playback set to 1080p.
    * Adjusted ISO parameter label to ISO RATING.
    * GUI timecode display no longer counts in whole second increments when not in RECORD.
    * Default setting in PLAYBACK changed to LOOK = CLIP.
    * Default setting for audio MIC LEVEL changed to +36dB.
    * OPACITY of LOOK AROUND are is now adjustable in MONITOR / CUSTOM menu.
    * WRITE LOG label moved to SYSTEM / SETUP / MAINTENANCE menu
    * Added REPEAT FRAME flag to VITC-2 HANC in HD-SDI PVW output.
    * Added IN-RECORD flag to VITC-2 HANC in HD-SDI PVW output.
    * Added CLIP NAME as metadata to VITC-2 HANC in HD-SDI PVW output.
    * Enhancement of USER PROFILE function.
    * Addition of STATUS display of camera parameters.
    * Addition of project CONFIGURATION function.
    ALWAYS READ ALL INSTRUCTIONS CONTAINED IN THE DOWNLOADED INSTALLATION FILES BEFORE PROCEEDING.
    NOTE: After upgrading firmware, a BLACK SHADING calibration should be performed. Detailed instructions are contained in the Operations Guide.
    If you have any questions or feedback, please contact RED Technical Support at www.red.com/support.
    Thanks, BC
    Frontline Infantry
    Aug 2007
    London/Sydney
