Thread: 3D and long lenses
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
  1. #11
    Jan 2007
    David, what would you do if you didn't have a set built for a kid's bedroom or other small interiors where you wanted a wide master? What lens would be the widest you would use? Could you shoot those anamorphic?
    Writer - Director
    Crowing Lakes.com
    In 3D? Well, I'm sure you can get away with a very wide-angle lens, it just depends on the amount of foreground, if you are worried about eye strain and distortion. It's similar to 2D, if you have to use a super wide-angle lens, you try to avoid telltale clues that bring out the distortion.
    David Mullen, ASC
    http://www.davidmullenasc.com
  3. #13 Roll is Critical Too
    Another thing that is really important with 3D is that the two cameras be perfectly square with each other. If one image is tilted in relation to the other people will not see 3D. That is one thing that the human brain just can't process.
    The further the cameras are apart the harder it is going to be to keep them aligned. IF you are getting them so far apart they have to be on separate tripods it is going to be a real challenge. Then if you have to pan them both and keep them pointed at the same subject it is going to be even more difficult.
    But it should be a really fun thing to try.
    Jan 2007
    I see. Maybe I should ask in a separate thread since this is the direct opposite side of the equation? Maybe it helps define the differences though.
    Aside from this particular scene which I am thinking about, all too often people shoot in very small rooms but need a wide. Like a an actual "normal" non-master-bedroom of about say 12 x 14ft give or take a few, unless you find a rectangular room that gives us some additional space on one side while allowing to easily make it feel smaller by shooting one way.
    No foreground is easy to do. For this scene the idea would be to get a large portion of the room and it's decoration, which contrasts with the dire situation the three characters are in. The purpose of the wide is to give a strong sense of where they are in a very quick shot as they run in looking for an important object.
    So I suppose something around 16mm might allow for that wide and 18mm might work for the three shots following that wide. Or hopefully 18mm and 21mm on 4.5k?
    Would the 16mm look horrible? What about 18mm, best stay away from it too? What might be the rough "OK" wide focal length?
    Maybe I should cut and paste this to an other thread. Let me know if anyone thinks I should.
    Writer - Director
    Crowing Lakes.com
    Senior Member Pedro Guimaraes's Avatar
    Apr 2009
    Burbank, CA
    Just got done shooting a whole feature on Angeniuex rouge 16-42.
    Most used focal length was around a 20mm. When we needed closeups we just put the camera close to the actors. This resulted in beautiful 3D as everything was very round and volumetric.
    Why? Focal length also affects 3d "volume". A long lens will ten to flatten objects a term in 3D we call "cardboarding" you will end up with a image that looks like a pop-up book.
    Wide lenses will tend to make things more "round" and give them more "volume".
    Also certain focal lengths + certain interocular combination's can result in "giantisim" and "miniaturization". This of course is an effect that can be done on purpose given the proper circumstances. Also if you are forced to use certain combination's there are some tricks to avoid some stereoscopic problems, mostly dealing with camera movement and background relationships.
    3D can be tricky......hehe......
    Generally wider lenses will be the most used lenses in a 3D filmakers toolbox.
    Pedro Guimaraes, SOC
    IATSE Local 600 - Operator
    Steadicam-Gimbals / Underwater / 3D cinema
    C-Motion Cvolution Wireless lens control 8 motor system for rent.
    Handsfree Segway for rent
    Ronin/Movi gimbals for Rent
    www.pgfilms.tv - Bio&Reel
    www.steadi3d.com - BLog
    www.cinemilled.com - Gimbal accessories & other cinema products
    Jan 2007
    Quote Originally Posted by Pedro Guimaraes View Post
    Very interesting.
    Watching avatar I felt a bit of the pop up book effect on a few shots in the sky people control room, towards the end of the second act I think. I wonder what happened there.
    David, have you shot any 3D tests yet? How soon might we see you shoot something in 3D?
    Writer - Director
    Crowing Lakes.com
    A 16mm lens in Super-35 is not too bad in terms of wide-angle distortion, particularly if it's cropped top and bottom to 2.40. It's definitely wide-angle though.
    The thing about small rooms is to avoid the temptation to use a super-wide-angle lens simply to get a wide shot. It may be better to just shoot in medium shots, or shoot a master framed through a doorway or window, or reflected in a mirror.
    Take a look at "In the Mood for Love", which was partly set in tiny apartments in Hong Kong; instead of removing walls (if these were sets), they shot through doors and even through doors and into mirrors to see the action. Yes, there are also wide-angle shots too, but the movie is a good example of working inside small spaces and taking advantage of having blocked-up frames where you only see part of someone.
    David Mullen, ASC
    Jan 2007
    Quote Originally Posted by David Mullen ASC View Post
    Hehe, yeah baby! I am having fun already!
    Writer - Director
    Crowing Lakes.com
    Apr 2009
    Burbank, CA
    Hehe...funny you should mention using mirrors David, as we used mirrors a few times during our production. It would make our editor really confused! But we made sure to make ample notations to help him out!
    ...but yes you make a good point about the use of mirrors. You do have to get creative but really allowed us to get some shots where you never would of been able to put the camera........inside cars especially.
    Senior Member Ketch Rossi's Avatar
    Jan 2007
    ITALY | USA
    Quote Originally Posted by Tom L View Post
    Is it more difficult to shoot long-lens footage, at say 300 - 400mm, in 3D? For example, if your intention was to film long-lens wildlife footage in 3D?
    Well Tom, I love the 200mm 40mm range in both 1.3 cropped sensor as off course in FF, and will be testing the 300mm for some 3D shots for "Rape of a Beauty" this will be extreme close up shots, and some detail shots, as well as some different compositions to see which one works best.
    Not yet sure if we will use a fixed Stereoscopic set up or a S3D Rig which will allow both movements of the Interocular distances as well as Divergence.
    But long telephoto lenses to my opinion work fantastic on 3D, just as explained here you will loose the 3D effect if shooting long landscapes.
    But since all my shots, apart from some buildings, remain in the 5' to 20' so I hope that we get in post what we need for the look I wish to get for this film.
