Click here to go to the first RED TEAM post in this thread.   Thread: red undead help
Results 1 to 3 of 3
  1. #1 red undead help
    Senior Member Eirik Tyrihjel's Avatar
    Oslo, Norway
    Hi, I am having problems running RED undead.
    I am in no way a tech/terminal kind of guy, I am the kind who really appreciates a good GUI! But I do exactlly as it says in the instructions and the terminal just triumphantly says "DONE!", and NOTHING is done...
    This is the disk:
    /dev/disk1
    #: TYPE NAME SIZE IDENTIFIER
    0: GUID_partition_scheme *320.1 GB disk1
    1: EFI 209.7 MB disk1s1
    2: Apple_HFS Macintosh HD 319.7 GB disk1s2
    And here are just a few of my unsuccesful attempts:
    eirik-tyrihjels-mac-pro:~ eiriktyrihjel$ redundead /dev/disk1 /volumes/Machintosh HD/REDfile4K-vol6-1/redfiles
    Output Dir: /volumes/Machintosh
    Done!
    eirik-tyrihjels-mac-pro:~ eiriktyrihjel$ redundead /dev/rdisk1 /volumes/4K-vol6-1/redfiles/
    Output Dir: /volumes/4K-vol6-1/redfiles/
    Done!
    Done!
    eirik-tyrihjels-mac-pro:~ eiriktyrihjel$ redundead /dev/rdisk1 /admin/Desktop/
    Output Dir: /admin/Desktop/
    Done!
    eirik-tyrihjels-mac-pro:~ eiriktyrihjel$ redundead /dev/rdisk1 /Users/admin/Desktop/4K-vol6-1/redfiles
    Output Dir: /Users/admin/Desktop/4K-vol6-1/redfiles
    Done!
    eirik-tyrihjels-mac-pro:~ eiriktyrihjel$ redundead /dev/rdisk1 /Users/admin/Desktop/REDfilessave
    Output Dir: /Users/admin/Desktop/REDfilessave
    Done!
    The difference in the location/naming of the output folder is a result of me trying different things.
    The disk is full of R3D data, out of which there are two empty folders, that we would like to try and recover. At this moment I am unsure if we can live without the data that is supposed to be in those folders.
    Any help on how to properly run redundead is very much appreciated, keep in mind that I am a fish out of the water around terminal, or directory structures, my mistake(s) could be very very basic, thank you!
    RED EPIC-M #646, EPIC-X #250, Scarlet-X P/L #2467 "Harbor", RED ONE #476 MX "MOTHER"
    Commercials | Live | Concerts | Corporate | RED rentals
    Red Pro Primes T1.8: 18,25,35,50,85,100 (all metric), red CF zoom 18-50 T3 (imperial), Red Pro Zoom 17-50mm T2.9 (metric), Red zoom 50-150 T3 (metric) + 300mm T2.8 (imperial) + tons of accessories!
    Leica Summilux-C series on order.
    www.groovyentertainment.com/english/
    Whether you think you can or think you can't - you are right. ~Henry Ford
  2.   This is the last RED TEAM post in this thread.   #2
    Red Team Deanan's Avatar
    Jan 2007
    I looks like it's unable to read the disk properly. Try using sudo and then the command:
    sudo redundead /dev/rdisk1 /Users/admin/Desktop/REDfilessave
    Senior Member Alex Carr's Avatar
    Aug 2007
    There is something missing or misplaced in about every command you've shown us. Are you trying to recover files from your Hard Disk? If this is the case, you will have to specify Partition # in the Command. *ie.(dev/rdisk1s2) (dev/rdisk0s2 ---> for Main HD, But not always for 100%)
    Here is a trick so that you won't need to learn more about the terminal.
    type: sudo redundead /dev/rdisk1s1 **(Drag and drop the -Output Folder- into the Terminal Window) The Directory Structure should appear into your Command. No Command can have any Spaces while Specifying a Directory *ie. Macintosh HD. ( the Smartest thing for every Mac user is to change your Main disk's Name to anything that doesnt have Punctuation, Symbols , or Spaces. Macintosh HD is a terrible Name, However MacintoshHD is absolutely perfect. Terminal interprets Spaces very differently, / %/ or something like that.
    Other options would be Testdisk and PhotoRec, Or R3d Data Manager.
    Union 600 DIT
    Apple Certified Pro FCP 7
    Red #778 'Leonardo'
