Thread: Metal Spin on ASIC
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 Metal Spin on ASIC
    There have been a number of posts from Jannard and Jarred about the ASIC "metal spin"... or "re-spinning the ASIC" or suchlike, but I haven't been able to find anything about exactly what that means!
    Everything I can find about metal spinning has to do with making rounded or 3d objects out of flat metal blanks. But I can't see how that applies to a computer chip like an ASIC.
    Could someone enlighten me?
    Thank you,
    Nelson
    Nelson Goforth • Denver, Colorado • 303.506.2456
    Lighting for Moving Pictures - Resumé: http://www.earthnet.net/~ngoforth/film
    Red Camera rentals: http://www.rockymountain4k.com
    Jun 2007
    The ASIC uses metal interconnects for all the gates on chip.
    A metal "respin" means correcting the errors/flaws in the interconnects on that particular layer.
    -sc
    Aug 2008
    Spin in this case means a round trip through the complete design, engineering, fabrication cycle to produce a new chip. In the case of the RED ASIC this involved only correcting design flaws in the metal conductive circuit layers as opposed to the silicon semi-conductor layers.
    Senior Member alex lemon's Avatar
    Jul 2009
    Quote Originally Posted by David Rasberry View Post
    any updates on how the re-spin is progressing?
    Senior Member David M's Avatar
    Jan 2008
    Quote Originally Posted by Nelson Goforth View Post
    Thank you,
    Nelson
    This page might be helpful. http://www.chipx.com/asic-options.html
    There are various types of ASIC, but it sounds like RED are using a Hybrid ASIC.
    If you were designing a computer system the usual way (say for a cellphone or the RED one) you would first select the set of off-the-shelf chips you need for the application, then design a printed circuit board that both physically holds them and electrically connects them together, and then get someone to assemble and solder them on.
    With a Hybrid ASIC, instead of having all the individual chips separately packaged and connected by printed circuit boards, the "chips" are actually all fabricated on the one pieceof silicon, at the same time, and directly connected together by the metallization layer(s).
    The metallization layer(s) serve the same purpose as the copper tracks on a conventional printed circuit board, and the construction is actually similar to the way printed circuit boards are made, except instead of using copper foil glued to a sheet of plastic, a layer of metal is vacuum-sputtered onto the chip surface. After that a layer of photoresist is added and the layer is etched to form the individual conductors, much the same way it is done with a printed circuit board.
    This has several advantages. It allows a much more compact layout, and the short connecting conductors speed up data transmission times. It can also be cheaper, but only if you make a lot of them.
    As with printed circuit boards, more complex circuits need more than one layer to make all the connections, so as each layer is finished, a layer of insulation has to be laid over it, and this then has to also be photo-etched to allow more connections to be made in subsequent layers.
    Generally, it's not that common for there to be actual "DC" wiring mistakes, it's more that certain signal paths turn out to be problematic when the device is fired up for the first time. (Which again is pretty similar to what can happen with a conventional PC board).
    A "Metal Re-spin" basically means a redesign of the "circuit board" rather than a re-fabrication of the whole chip. Applying the metallization is generally a much lower-tech operation than actually fabricating the chips themselves.
    As to why it's called a "Re-Spin", I have no idea. I know the way they apply the photoresist is called "spin coating" where the silicon wafer is spun at high speed (like a CD or record) and a single drop of the coating is dripped onto it. When it hits the surface it instantly spreads out into an even coating. They have to do this for every processing step in the fabrication process. Whether this has anything to do with it, I don't know.
    Now that was some dense information presented very clearly!
    David
    "A revolution is not a bed of roses.
    A revolution is a struggle between the future and the past." – Fidel Castro
    Senior Member Leif Thomas's Avatar
    Jun 2007
    I LOVE learning things in a dense way. Thanks David!
    Leif Thomas
    - DIT -
    Epic M, Epic X & Red One MX rental
    http://www.welldone.tv
    Thanks for the clarification everyone.
    Banned
    Jun 2009
    Los Angeles / San Diego / Miami
    That was a well laid out post professor David M.
    First time I've actually got a grasp of ASIC.
    Senior Member MichaelHalsell's Avatar
    Aug 2009
    New York
    Quote Originally Posted by alex lemon View Post
    No updates directly, but the word on the street is that Epic prototypes will be available for inspection at NAB 2010. So I hoping that this is our indirect answer.
Tags for this Thread
View Tag Cloud
