Click here to go to the first RED TEAM post in this thread.   Thread: Best Practices: Redcine-X & Integration with other apps
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Best Practices: Redcine-X & Integration with other apps
    Senior Member Ryan E. Walters's Avatar
    Sep 2007
    Beaverton, Oregon
    As of this writing Redcine-X is the only application that supports the new color science (FLUT, etc.), and it is the only program that can process the MX footage until the other applications are updated via the SDK. So, with that being the case, I wanted to get peoples input and advice on the best practices of using RCX and the integration with other grading apps.
    From what I have read so far, at this point in time these are the recommended settings for RCX:
    - Use RedColor & RedGamma.
    - White balance to a grey card
    - Use High Debayer
    Then you should export out in the resolution and codec you need for your editing / grading app. From what I can tell, DPX is the preferred codec. However, I have seen some impressive results from ProRes 444 ...
    Here are some questions I have:
    - Is there anything else that should be done before leaving the R3D world?
    - Is it best to just render out a flat "grade" with no other adjusted settings and then grade the footage accordingly in your grading app or should a complete one light grade be done?
    - If doing a complete one light grade on the clip, I assume that I should treat this as my primary in room in the grade and get the clip balanced in the direction I want to head- is that correct?
    - If this is the case (one light), then what is the best way to set my Lift, Gamma, Gain points? I'm use to working with a waveform not a histogram. I assume that I would use the Lift control to slide the histogram down to the blacks, then adjust the Gain, and balance the Gamma. But should I use the FLUT control instead of adjusting the Gamma? Or should I use the FLUT first, then adjust the Lift, Gamma, Gain?
    Ryan E. Walters
    Cinematographer
    www.ryanewalters.com - Tutorials - IMDB - Twitter - REEL
    Specializing in Digital Cinematography
    "Too often people get caught up in the technical end of things ... They are missing the point completely. This way there is no proper input of individual personality." Vittorio Storaro, ASC, AIC.
    Whirlpool GC5SHAXVS / WFW9400SZ / GFE471LVS / GU3600XTVY / GH7208XRS / WFW9400SZ / WED9750WW / GLS3665RS / and on back order, but expected in soon MTKS-230-C
    Quote Originally Posted by Ryan E. Walters View Post
    As of this writing Redcine-X is the only application that supports the new color science (FLUT™, etc.), and it is the only program that can process the MX footage until the other applications are updated via the SDK.
    Err... SCRATCH supports the new color science and can process MX footage through RED Rocket at faster than realtime.
    Lucas
    Lucas Wilson
    ASSIMILATE, inc.
    LA, CA, USA
    REDuser Sponsor Chris Parker's Avatar
    Jan 2007
    can it do that TODAY with 5.0 lucas? i was under the impression it couldn't and that would be an update coming at a later time. would be great if we could do it now though!
    Sep 2007
    Beaverton, Oregon
    I know that there are several apps that have unreleased versions that support the MX footage (Apple Color also comes to mind). But it was my understanding from what I have read that other then RedCine-X nothing else has been officially released. If Scratch is doing that now, that is great.
    Ryan E. Walters
    Cinematographer
    Quote Originally Posted by Chris Parker View Post
    Ryan/Chris - you are correct in that the release version of SCRATCH cannot do it.
    That being said, if you are a SCRATCH customer and are working right now with MX footage, you should contact me offlist for a more in-depth discussion of timelines.
    Best,
    Lucas
  6.   Click here to go to the next RED TEAM post in this thread.
  #6
    Red Team Deanan's Avatar
    Jan 2007
    RocketCineX also support the new color science.
    The SDK has also started to ship out with the new color science.
    A couple of vendors have already shown support for it in their beta builds.
    Jan 2007
    great news deanan, so does that mean the SDK is in the hands of Assimilate, Quantel, DVS, Autodesk, Blackmagic, etc.?
    We are certainly waiting for the good word from those folks to comfort clients with the knowledge their established post path is good to go.....
    Senior Member Felix K.'s Avatar
    Apr 2009
    Germany
    That being said, I must say, as a FUTURE owner of the Scarlet, I'm starting to get confused about the software RED has been, is and will offer. The homepage, if you allow me this little criticism, does not introduce any of the mentioned programs. I think it would be great if there was a page showing what's what and what it needs etc etc...
    just my 2c
  9.   This is the last RED TEAM post in this thread.   #9
    Jan 2007
    Quote Originally Posted by Felix K. View Post
    just my 2c
    We have a new website coming that will show this better.
    It is.
    Senior Member Taylor Morrison's Avatar
    North of NYC
    Hans? Love to see this in my precious clipfinder as well..
