Thread: Compatible hard drives on set?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 Compatible hard drives on set?
    Junior Member
    Sep 2007
    This may be a silly question, but what type of hard drives is everyone using to unload 4k footage onto? The general amount of HD space needed? A professor of mine thought that no standard consumer HD is fast enough - Any thoughts? Thanks!
    Quote Originally Posted by La1120 View Post
    we used the G-Raid Mini -
    http://www.g-technology.com/Products/G-RAID-mini.cfm
    we actually only G-Tech drives for edit & finish - we are running their G-Speed XL rackmount until in out Scratch grading suite -
    Your professor is probably unaware that 4K coming off RED One onto the compact flash cards is compressed using RED's wavelet based codec, REDCode, down to about 27-28MB/s. Most desktop hard drives, and current top-of-the-line compact flash cards can handle it just fine.
    Uncompressed 4K at 300-400MB/s, well that's another story...
    Senior Member Dominic Jones's Avatar
    Jan 2007
    Brighton, UK
    I've seen a few posts recently that have made the same mistake as your professor has made, so in an attempt to clear this up:
    There is a big difference between capture/playback drives (in terms of speed required) and back-up drive spec. When realtime performance is needed (i.e. for capture or playback @ full resolution) you will need fairly fast read/write speeds - a 7200rpm array of RAID mode 0, 3, 5 or 6 will do you fine with any reasonably up to date controller. RAID 0 is by far the cheapest (although also by far the least safe) of these options, needing less disks (2 vs minimum of 3), losing you no storage space, and using a much more common (and therefore far cheaper) controller interface (RAID 0 can be found built into most motherboards these days, and external RAID 0 enclosures are plentiful and reasonably inexpensive).
    When you don't need RT performance - e.g. when you're backing up on set, as you are talking about buying drives for - then the speed becomes irrelevant, other than how quickly you'd like to have the RedDrive/CF unit/whatever camera media you are using ready to wipe and shoot again. This is a non-realtime process (i.e. it doesn't matter how long it takes from a technical point of view - only your workflow requirements constrain it) and therefore you could, in theory, use a single 5400rpm IDE drive to back up onto. I wouldn't recommend that, by the way, but there's nothing technically stopping you from doing it!
    So there you go, I think that's about the long and short of it - just remember to work out when you do and don't need RT performance...
    Junior Member
    Sep 2007
    Thanks for the clarification!
    what is speed limit of your G-Speed XL?
    antoine.
    Senior Member Poi Boy's Avatar
    Mark, how long did it take you to download 8gig red cf to g raid mini and what card reader did you use ? How many cards where you using on your car extraveganza ?
    Aloha
    -A
    Alex Viarnes
    Poi Boy Productions
    Senior Member Jochen Schmidt-Hambrock's Avatar
    South of Munich, Germany
    Are you from Munich? The camera prof. there seems to spread a bit dated info around. (Talked to a young director fresh from the HFF a few weeks ago)
    But this will change within a few weeks I guess. :-)
    Jochen
    www.jochenschmidt.de
    http://imdb.com/name/nm0773276/
    twitter: josch11
    RED Rental info: http://www.redrent.de/contact-redrenta.html
    Senior Member jaadgy akanni's Avatar
    Feb 2007
    Manhattan, Uptown Baby!
    I'm surprised no one ever mentions these GLYPH babies with FW400, FW800, and eSATA, and are the ones I use with my NLE's and also Pro tools.
    http://www.glyphtech.com/site/products/gt050q.html
    i just got this one and it performs wonderfully:
    http://www.glyphtech.com/site/products/gt062.html
    Senior Member Michael Morlan's Avatar
    Austin, TX
    I'm using the AMS Venus DS3R with great success. 2x IDE or SATA (depending on model), removable drive trays, FW400/800, USB, RAID 0, RAID 1,JBOD.
    This may end up as my on-set backup drive solution. Fill the RAID 1, split the drives and send them to separate facilities. Note: 500GB drives take around three hours to format into a RAID 1 so include time to build a RAID overnight before a shoot.
    Michael Morlan
    DP / Local 600 Operator
    http://michael-morlan.net
    http://talltalepictures.com
    Red One MX . Epic-X . RPP's, 18-85mm T2.9 zoom, etc.
