Thread: C-Mount Lens on a Scarlet ??
Results 1 to 2 of 2
  1. #1 C-Mount Lens on a Scarlet ??
    Senior Member George D.'s Avatar
    Oct 2008
    N. California, USA
    I just read in this forum that it is possible to use a C-Mount lens on the upcoming Scarlet Camera.
    My question is, how? In other words, is RED making a C-Mount Adapter for this camera? And, how can a "standard" 16mm lens like that "cover" the 2/3" Scarlet Sensor?
    Also, if this is TRUE, then I assume you could also use one of these lenses on the RED in the 2K mode. ??
    If someone would clarify this, I'd greatly appreciate it.
    Aug 2008
    C-mount was one of the original announced interchangeable lens mount options announced for Scarlet.
    I hope they have designed the mini-red mount so that c-mount lenses can be mounted with a screw on flange adapter like Bolex did with the EBM, but I am not optimistic about this.
    2/3" video standard is roughly equal to the projection aperture of standard 16mm film so 16mm lenses cover it just fine. One reason for the format's popularity. It originated at a time when 16mm cams were used for most TV news field production and the lenses could be used on the old B&W vidicon cameras interchangeably with no difference in coverage angles or field of view.
    See here: http://reduser.net/forum/showthread....626#post555626
