Click here to go to the first RED TEAM post in this thread.   Thread: Get the most out of RedCineX?
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1 Get the most out of RedCineX?
    With the new FLUT controls and everything being introduced, I'm just a little overwhelmed. Just wondering if anyone could give a step by step of how the process footage. When should I use the FLUT? I guess I should be using Redcolor and Redgamma? I'm asking this because I'm interested in Re-grading some ordered footage, especially some stuff that I would classify useable. I should I be crunching the blacks with curves or should I use the new shadow control. Thanks, Ryan.
  2.   Click here to go to the next RED TEAM post in this thread.
  #2
    1) REDColor / REDGamma - both very pretty looking and gradeable, and compatible with a standard REC709 display.
    2) Set white balance as accurately as possible - you'll get better colorimetry - more accurate colours and better separation
    3) Adjust FLUT control to get mid-greys where you want them.
    That's the basics. After that I like the "Shadow" control to tighten up the left side of the histogram.
    Graeme
    www.red.com - 5k Digital Cinema Camera
    Science enables stories. Stories drive science
    FLUT™, Image Processing, Colour Science and Demosaic Algorithms, REDRAY 4K delivery
    Nov 2007
    London
    Quote Originally Posted by Graeme Nattress View Post
    Graeme
    So is it fine to go with REDColor/ REDGamma for MXF file export and a REC709 finish?
    I've been wondering about this for a while...
    Thanks for any further info.
  4.   Click here to go to the next RED TEAM post in this thread.
  #4
    Gosh yes!
    Graeme
    That all makes sense to me. How do I white balance the scene if there is nothing white in it? Do I just go by what feels right? When you say to "adjust FLUT controls to a middle grey where I would want them", what exactly do you mean by that? Can I pull in something that is middle grey and balance off of that? Thanks
    I have two shots that are pretty important to me. Underexposed is the main problem and I was wondering if anyone wanted to take a whack at them and see what's the best possible image we could get out of them? Let me know and what would be the best possible way to send them to you?
    3) Adjust FLUT™™ control to get mid-greys where you want them.
    Graeme
    Graeme's words are gospel. I've dramatically improved my grading results (in Color) by following his above procedure in REDCine-X first.
    I'm using the REDRocket to perform full-debayer down to my deliverable format (i.e. 1920x1080 ProRes444). Using REDColor / REDGamma, my starting point in Colors looks like what the DP intended on set, but enough latitude is retained in the ProRes files to make a nice impact with my grade.
    Best,
    - Jordan
    P.S. If the DP isn't involved, or the production isn't happy with his decisions on-set (usually unheard of, but possible, in theory) I would go with REDLog gamma instead, which gives me even MORE latitude in Color, albeit without the aid of the pretty / client-friendly 'look' as a jumping off point.
    Last edited by Jordan Livingston; 02-25-2010 at 10:53 PM. Reason: added the 'P.S.' thought
    Jordan Livingston
    Leading a double life...
    IATSE Local 600 ICG DIT
    www.DIGILOID.com
    Independent Filmmaker
    www.JLPMOVIES.com
    Quote Originally Posted by Ryan T. Gibb View Post
    Hi Ryan,
    I'd love to take a crack at them in REDCine-X first, and send you a still frame... If that doesn't do the trick, we can go all the way into Color and see if they can't eventually be restored.
    Can you upload the R3Ds to an FTP server?
    - Jordan
    Jordan Livingston
    www.DIGILOID.com
    www.JLPMOVIES.com
    Senior Member Luca Immesi's Avatar
    Apr 2008
    Italy
    Quote Originally Posted by Jordan Livingston View Post
    This is for me the best workflow for R3Ds in Color. The only difference I like to export in 2k if I need to reframe a bit.
    Luca Immesi | Filmmaker, Director, Red specialist, Editor, Colorist
    Rent our 2 Red Epic X and Red One MX! Unbelievable prices!!
    Ritual First Italian Movie shot on Epic - With the partecipation of Alejandro Jodorowsky - Please like our Fb page :)
    ritual-apsychomagicstory.com
    imdb.com
    esperimentocinema.com
    Knowledge is king
  10.   This is the last RED TEAM post in this thread.   #10
    If there is no white or grey reference in the shot, then there should be! Or at least for every lighting set-up. Or pick a number that looks right for the shots. What you are doing with this is guiding the colorimetry for accuracy.
    Usually, the key parts of the shot that you've exposed for are the mid bright things in the shot - use FLUT control to ensure that they're there. But obviously, artistic needs may guide them brighter or darker.
    Graeme
