Thread: Canon EOS mounts for Red Pro Primes
Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 74
  1. #11 Done!!!
    Senior Member Jacek Zakowicz's Avatar
    Jun 2008
    After a bit of debate I decided to build a self contained PL to EOS adapter for ALL Canon VDSLRs so it's switchable between 5dII 7D, 1D MIV, and my T1i
    The adapter kit quickly munts on the camera, much like a lens and instantly turns it into a PL cam. Now use of RPPs will require modified PL mounts, but once swapped the RPPs will work on BOTH R1 and Canons. Owner operators, Rental facilities rejoyce!!! The support plate is mounted on the adapter so there is no strain on the camera mount whatsoever.
    I added an adjustable carry handle(also integrated with the adapter)
    Advantages:
    -no mods to the camera required so it warranty is intact.
    -the DSLR retains it's value so when new one comes out you can swap the camera- the adapter will work.
    -all Angenieux Optimo zooms work with no modifications at all.
    -now quick swap of cine lenses for use of Canons as a B cam is possible for perfect (lens)color and perspective match.
    Let me know if anything else is needed- this is the time to change things!!!!
    Jacek Zakowicz, Optitek-dot-org, jacek2@optitek.org
    Professional Broadcast and Digital Cinema Equipment
    Senior Member Larry McKee's Avatar
    Jan 2007
    Houston, TX
    Dang, Jacek. You are making it really hard for me not to buy a DSLR. Love the integrated handle. As far as suggestions...maybe an integrated rod mount system?
    Epic-X 1136
    Nov 2007
    How can lenses clear without hitting the mirror?
    Mitch Gross
    Applications Specialist
    AbelCine
    mitch@abelcine.com
    212-462-0100
  4. #14 lenses that clear
    Jun 2008
    Angies clear, Cooke zooms clear, RPPs clear, albeit with my PL mount-shorter pilot. I'm offering RPP owners this option for A/B cam use- as promised This is Red forum after all..
    Jan 2007
    Houston, TX
    Would it be practical to make one of these in a Nikon mount?
    Epic-X 1136
  6. #16 what system
    Jun 2008
    Quote Originally Posted by Larry McKee View Post
    mini rods would be pretty easy to implement..
  7. #17 not easily
    Jun 2008
    Nikon is very tight- 2.5mm missing....
    Senior Member Mike Prevette's Avatar
    New York, NY
    awesome!
    _mike
    "One for a meal, One for the reel, or One to learn something"
    Senior Member Tico Llaurador's Avatar
    Jul 2007
    Redondo Beach, CA
    OK, Jacek, you win. I'm sold on this. Good to have in the kit. Bring it on!
  10. #20 One down.....
    Jun 2008
    Quote Originally Posted by Tico Llaurador View Post
    Thank you Tico, you are first in line...much appreciated
